Is it possible to brick an FRM by testing it on another car?
01-22-2020, 04:43 PM | #1 |
Rep 11
A friend of mine has an '07 n54 that is supposedly having electrical issues like, doors not locking, E-brake light permanently on, windows not working ,Etc. He believes his FRM is fried and wants to see if swapping in my '09 n54 FRM will change anything to help confirm his is bad.
My question is, will I have any issues with my FRM once its back in my car? For example, will it have to be recoded or anything like that? I would assume its pretty much a plug and play thing but I would like to avoid bricking or messing up my FRM. |
01-24-2020, 11:42 PM | #2 |
480
Rep 1,600
You could end up in the same sinking boat as your pal. Power interruption to the FRM is a very common reason for failure. Eg. battery flat, battery disconnection.
Didn't BMW extend the warranty in USA for FRMs? |
02-04-2020, 08:45 PM | #3 |
94
Rep 298
Drives: 2011 BMW 335xi
Agreed. Looks like the FRM is dead, and I would not recommend taking yours out. Those things are very fragile. I bricked mine by just trying to flash it. Probably had a voltage fluctuation or something, dunno, but I ended up shelling out almost $500 for a new one. And that's just the part, I installed it myself.
Does your friend have access to INPA or NCSEXPERT? I would try reading from the module.
2011 BMW 335i xDrive E92 N55 Alpine White\M-Sport /BMS CAF/HPS CAI/VRSF 5" FMIC/VRSF CP/VRSF Inlet and Outlet/VRSF Catless DP/NGK 1-Step Colder Plugs/xHP Stage 1//MHD Stage 2+
02-09-2020, 01:23 PM | #4 |
Rep 9
FRM's are fragile, but used ones are pretty cheap. I had a bad junk yard one (got my money back), one that lasted less than a year before dying and my current that is on a couple years now and doing just fine.
$500 for a new one or under $50 for a used one. Not that hard to swap. Same as my HVAC controller; I had to buy 4 before I found a good one, but under $50 and got my money back on the used ones (and sold all the bad used ones, listed as being bad, for about what I paid for my good one). 2 minute swap, so not a big deal there. That said, none of those listed symptoms were what my car had with bad FRM's. It was always lighting related. |
