BMW X3 Forum
BMW X3 Forum
Welcome to the ultimate BMW X3 community.
      01-13-2020, 02:54 PM   #1
tonycota
BMWX3si
Mexico
Drives: X3si 2008
Question x3 2008 DOESN'T START
I have a 2008 X3 with new battery, last sunday try to start and nothing happens not a single light nothing completely dead, bought a new battery and nothing.
Please help
      01-14-2020, 04:15 PM   #2
tonycota
BMWX3si
Mexico
Drives: X3si 2008
ok my friend thank you for the tip, i will try that.
      02-06-2020, 10:05 PM   #3
DannySan
Drives: 2007 x3
Originally Posted by X3MS View Post
07 and up X3's require the battery to be registered with the ECU. You will need to purchase a code scanner with battery register ability. The Foxwell NT510 will do this.
Scanner video of battery register:
That looks like a good scanner.
      02-08-2020, 06:55 AM   #4
X3MS
MARANATHA!
X3MS's Avatar
12
Drives: 2007 X3 M-Sport
First Generation X3's Don't Have IBS.
First generation X3's don't have IBS, and won't require battery registering. Was given some bad info, dismiss previous post.
      02-11-2020, 08:58 PM   #5
tonycota
BMWX3si
Mexico
Drives: X3si 2008
thanks
It was a bad battery, replace it a now is working.
      02-22-2020, 02:39 AM   #6
sidyid
Living it up at Hotel la Mariposa.
Spain
Drives: BMW X3 3.0 SD
I have a 2006 X3 35SD and I can turn on the ignition, get all of the lights but the car will not crank, it does not have IBS? any ideas guys?
      03-12-2020, 04:42 AM   #7
gazza6
South Africa
Drives: BMW X3 E83 2.0D xdrive
is the starter making any noise or movement at all?
might sound silly, check the wires on the starter motor.
if these are even loose you might not get it to even make a sound.
you might have a main fuse on the starter main line from positive.
maybe just maybe....
      05-26-2020, 05:32 AM   #8
matrixhunter
matrixhunter's Avatar
14
Drives: 2008 BMW X3 SI M + 2014 M235I
The starter ground wire is the issue. You can locate it near the passenger wheel well. It might be fully broken or heavily corroded.
