Bimmerpost
4 Series
Technical Topics Wheels and Tires Tire pressure?
      12-28-2019, 02:15 PM   #1
Prissy
Prissy's Avatar
Taiwan
1069
Drives: M340i
2015 BMW F30  [5.50]
2020 M340I  [0.00]
2017 X3  [0.00]
2008 BMW E92  [9.00]
2010 BMW E92  [10.00]
Tire pressure?
Can someone let me know how much air I should put into my new tires? They are 19" staggered RFT. Thanks in advance.
      12-28-2019, 02:55 PM   #2
Burrcold
5297
Drives: 2024 M3 Comp xDrive
Just check your door jam.
      12-28-2019, 04:11 PM   #3
DomiGijzen
DomiGijzen's Avatar
Netherlands
70
Drives: BMW iX3 MSport High Exec (G08)
Or in idrive.
Grz D.!
      12-28-2019, 04:49 PM   #4
Prissy
Prissy's Avatar
Taiwan
1069
Drives: M340i
2015 BMW F30  [5.50]
2020 M340I  [0.00]
2017 X3  [0.00]
2008 BMW E92  [9.00]
Originally Posted by DomiGijzen View Post
Or in idrive.
Or in idrive.
Originally I had 19s 225F/225R all season, and now switched to 19s 225F/255R. The brands are all the same. Looking at my door sticker, it doesn't tell em how much air for the 255R. And the iDrive menu doesn't show all season staggered, only shows summer staggered. Should I just use summer staggered?
      12-28-2019, 04:58 PM   #5
Burrcold
5297
Staggered are the same psi. Most likely 38 psi all around.
Appreciate 2
Prissy1069.00
BayM34072.00
      12-28-2019, 06:04 PM   #6
Prissy
Prissy's Avatar
Taiwan
1069
Drives: M340i
2015 BMW F30  [5.50]
2020 M340I  [0.00]
2017 X3  [0.00]
2008 BMW E92  [9.00]
Cool. 38 psi for RFT is okay? Or that's for non RFT?
      12-28-2019, 06:27 PM   #7
alpinewhite3
alpinewhite3's Avatar
556
Drives: Currently searching
Is your car x-drive or RWD? i have been doing extensive research on tire pressure and trying out different pressures to maximize steering feel/grip/ etc.
      12-28-2019, 06:30 PM   #8
Burrcold
5297
Use the same as the front. Again with a staggered set up it's the same as the 225 front tires.
      12-28-2019, 06:50 PM   #9
Prissy
Prissy's Avatar
Taiwan
1069
Drives: M340i
2015 BMW F30  [5.50]
2020 M340I  [0.00]
2017 X3  [0.00]
2008 BMW E92  [9.00]
RWD
Thanks bro. I am gonna give that a try.
      12-29-2019, 12:03 PM   #10
alpinewhite3
556
Originally Posted by Prissy View Post
RWD
My 330i is RWD (225/45/18 all season Pirelli P7 Cinturato runflats all around) and door jam recommends 32 front 38 rear.
Tried the following combos:
32F/38R: Steering felt heavier but it didn't feel as quick or crisp. Grip was great and tires did not squeal under hard cornering as much. Felt like I could take corners fairly hard without worrying about oversteer. I felt like i would know well before i pushed the grip limit. This is why BMW recommends this pressure. Their #1 goal is safety and preventing oversteer/spin outs is more important than steering feel.
38F/38R: Steering felt a bit quicker and turn in was crisp and quick. Great steering feel but I felt like i sacrificed some grip b/c of the added front pressure(less contact patch up front) Tires squealed more under hard cornering and could sense an oversteer situation possible without much warning or notice. Also-car felt darty at high speeds bc of the crisp steering/smaller contact patch of front tires.
35F/38R: This is why i ultimately settled on. Seemed like the best compromise of steering feel and grip. Steering was not too crisp but not too lazy either and car felt grippy and still less likely to go into an uncontrolled oversteer situation without an adequate warning.
Anyway, hope this helps. There is no magic perfect pressure combo. It really depends on what you prefer and are looking for in terms of grip was steering feel. That being said-i would avoid going above 38 psi in any tire. Car will be too bouncy/darty and you will sacrifice a lot of grip.
Let me know what worked best for you. Like others have said, staggered set up should not really matter when it comes to pressure front/rear. And as always-make sure you set the pressure on cold tires. (havent been driven on for at least 3-4 hours)
Appreciate 3
      12-29-2019, 01:50 PM   #11
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
443
Drives: BMW G20 330i RWD M Sport
This is my 330i RWD staggered setup as per settings in door jam.
Front 8j x 19 with 225/40 R19 Michelin Pilot Sport 4 S (Performance). Pressure 2.7 Bar
Rear 8.5j x 19 with 255/35 R19 Michelin Pilot Sport 4 S (Performance). Pressure 2.7 Bar
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
Prissy1069.00
      12-29-2019, 02:01 PM   #12
Burrcold
5297
Which is 38 psi approximately.
      12-29-2019, 02:11 PM   #13
Tam the Bam
Grumpy Old Git
443
Yep. 2.7 bar is 39psi according to google.
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
zazzau750.00
      12-29-2019, 02:29 PM   #14
Burrcold
5297
Yes. Although for those same wheels and tires, BMW recommends 38 psi (so either their conversion math is off or it doesn't make a difference )
      12-29-2019, 03:52 PM   #15
RedKloud
RedKloud's Avatar
736
Drives: BMW i4 M50
My manual says 38 PSI for staggered 19" tires, but my TPMS says 37 :.
      12-29-2019, 04:47 PM   #16
Prissy
Prissy's Avatar
Taiwan
1069
Drives: M340i
2015 BMW F30  [5.50]
2020 M340I  [0.00]
2017 X3  [0.00]
2008 BMW E92  [9.00]
RWD
RWD
Looks like 330 and 340 doesn't share the same pressures (see my label). I had the same tire set up as you before I swapped the rears to wider.
Right now I am at 38 fronts and 40 rears and it rides pretty good. I might test 38f/42r and I will report back in case someone's interested.
I also believe the Pirelli Cinturatos P7 RFTs are trash to begin with.
      12-29-2019, 04:49 PM   #17
Prissy
Prissy's Avatar
Taiwan
1069
Drives: M340i
2015 BMW F30  [5.50]
2020 M340I  [0.00]
2017 X3  [0.00]
2008 BMW E92  [9.00]
Do you have rfts?
      12-29-2019, 05:03 PM   #18
Tam the Bam
Grumpy Old Git
443
For info this is what is on my door jam. You will see there are different tyre pressures depending on load.
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      12-29-2019, 08:22 PM   #19
RedKloud
RedKloud's Avatar
736
Drives: BMW i4 M50
Do you have rfts?
Non-RFTs. But according to the manual pressures are the same for both.
      12-30-2019, 09:41 AM   #20
Prissy
Prissy's Avatar
Taiwan
1069
Drives: M340i
2015 BMW F30  [5.50]
2020 M340I  [0.00]
2017 X3  [0.00]
2008 BMW E92  [9.00]
The tires will prob reach 39 when it's warm. Do you happen to have summer or all season tires?
      12-30-2019, 10:08 AM   #21
themur
67
Drives: BMW M340i
2020 BMW M340i  [0.00]
Mine's the same. Manual calls for 38 but iDrive is 37.
      12-19-2020, 07:15 PM   #22
Chris DW
Australia
Drives: BMW 330i G20 m sports
I’m not really sure if the recommended tire pressure @ 38 psi on my G20 m sports is even correct if it’s on solo drive daily. I’ve recently check my rear tire tread depth and the signs tells me that it’s over inflated... I’m getting centre wear. Have decided to drop my rear positions to 33 psi and reduce the fronts to 35 psi. The car in on 19” and has only done 11,000 kms .
g20
