Need tire advice
12-26-2019, 04:20 PM | #1 |
E92 335i
142
Rep 340
Need tire advice
Hey guys,
I own a 335is 2012 on (stock suspension) Just purchased a set of wheels BBS GT-RS 19" specs are below Fronts 19x8.5 +35 Rears 19x9.5 +40 I'm currently looking into purchasing some tires wondering what would be an ideal spec on tires (I perfer something that would give me good traction) since i do canyon runs.
FB: SOCAL BMW LA
IG: SOCAL_BMW_LA Cruises / Meets / Canyon Runs (BMW CA EVENTS) |
12-27-2019, 01:52 PM | #2 | |
Budget Builder
37
Rep 114
12-27-2019, 01:56 PM | #3 |
2124
Rep 2,758
This should help you out; https://support.apexraceparts.com/hc...-Fitment-Guide
I went with 245/35 and 265/30-19's with the same rim widths as you, but haven't mounted the tires yet. |
01-02-2020, 09:57 PM | #4 |
681
Rep 3,696
I have 18’s so it might not be the same... I used to run MPSS tires (just under $1k otd) and switched Firestone Indy 500’s (summer tires) for under $450 otd. While they are not an exact replacement for MPSS... at 50% the cost they are a great compromise. I could only get almost 30k miles on the MPSS tires (wires starting to show on inner of the tire)... but with the Firehawk Indy 500’s I have already exceeded 30k miles and still have a good amount of tread left. I only street drive, no track... But i rotate and do alignment check with the tires on each oil change.
Only issue is when you park the car overnight, you get a flat spot on the tires until you start driving a mile and it goes away. I haven’t noticed the flat spot for a long while since i have put on some miles on the tires tho (but noticed it a lot when new). |
01-03-2020, 12:28 AM | #5 |
123
Rep 331
The indy 500s are hard to beat for the price. A little more performance would be the extreme contact sports and then the ps4s for the best all around performance
01-16-2020, 08:57 AM | #7 |
Rep 11
go 235 35 19 front and 275 30 19 in the rear, Im running this setup on a e92 328 coupe, 265 30 19 in the rears the front will be higher than the rear
