Injector refurb job ?
12-25-2019, 05:33 AM | #1 |
217
Rep 1,909
Hey guys, I’ve opened up everything to do the valvecover gasket job, I don’t believe the injector tips are spraying the way they should, the microscopic nozzle tips have to create a spray pattern optimal for combustion, the way they dame out they’re burnt up and I can’t sand them down or clean the tips coz I might clog the pores... anyone knows someone who refurbishes these
Thanks She has 75k in the clock
Mods: 7" VRSF FMIC, Forge DVs, RB PCV, BMS Oil Cooler, VRSF DPs, MHD, JB4g5, OFT DIYs: Walnut blasting : Trans Oil at 45k, w Filter at 65k : Diff Oil Flush @ 45k : WP&TS @ 69k : Alternator @ 79k --- E70d Alphabet Soup del 44.4k : JR Stg2.25 tune : Buzzken Catted Exhaust : Trans fluid drain/ fill (3 Qrts), both Diffs fluids flushed Wheels: Style 95s on PSSs (Sold): AG 359s on S04s : 162s on Blizzaks : Rohana RF1 Matt black
12-25-2019, 05:52 AM | #2 |
Kind of a Big Deal
167
Rep 857
I would check in with Matt Whitbread or Andrew Rodriguez or the many other super knowledgeable people on this forum (or the FB forum). There has been a post on refurbishing injectors in the last week -- maybe it was you! As you suggest the tips are super delicate and they can be destroyed by well meaning efforts at cleaning.
12-25-2019, 11:55 AM | #3 | ||
1231
Rep 1,101
I've got a couple spare injectors that I've been thinking of cleaning up professionally. I'll probably contact Rodriguez about that as well since you suggested it (I hadn't even considered they might do it, never seen it advertised on their website). |
12-25-2019, 11:52 PM | #5 |
160
Rep 803
I'd just soak the bottom 1/3rd in kerosene in an ultrasonic cleaner which should dissolve the soot. I did that with my vw tdi injectors before getting new nozzles.
12-26-2019, 02:34 PM | #6 | |
Kind of a Big Deal
167
Rep 857
https://www.e90post.com/forums/showthread.php?t=1290545 |
12-30-2019, 07:18 PM | #8 | |
Know's a guy that know's a guy...
5637
Rep 1,905
https://ocaladiesel.com |
12-31-2019, 01:29 AM | #9 |
870
Rep 2,615
Every injector that is tested by a qualified outfit will end up with clean tips. I’ve tested many and asked why the tips are clean. Tips are not getting cleaned on purpose. It’s a byproduct of testing fluid running through them. Go figure it’s not diesel they use.
12-31-2019, 01:27 PM | #10 |
14
Rep 84
you can open injector but it's torqued at some 100nm as I seen on youtube. you can open, there are few tiny metal parts in the tip. you can soak them up in ultrasonic cleaner that can be bought for some 50 bucks used for jewelry cleaning.... guys are doing it, but I wouldn't do it myself since I am lacking tools and patience and technical prowess, where I can't even remove fricking pressure converter plate burried in a tight s..hole where I cant even reach with my fingers
