12-22-2019, 03:57 PM | #1 |
91
Rep 183
M550i Order & Qs - Coming from V3 CTS-V
Hello all, I recently ordered:
2020 M550i
MSRP was just north of $86K, and I got the 36/15K/$2K lease to $980 aft tax monthly payments. I'm happy with the deal. I'm coming of a 640HP V3 (current gen) CTS-V. I LOVE this car, but GM quality and service make it really hard to hold on to it after the lease. I'm also on my 2nd set of front tires, and 4th set of rears, currently PS4S in 305. I had a CT6-V on order since April, but the lease on that vehicle was around $1,500, and after all the issues I had with waiting I finally cancelled that order and went with an M550i described above. When I test drove the M550i, I never hammered it. I normally respect vehicles that I don't own. The car seemed quick and I figured it's worth a shot if I wanted to stay on a sub $1K lease this time around. The CTS-V handles great, especially on the track. Yes, the rear will step out on the street, but if driven right the car handles better than any sedan I drove to date sans the new M5, and there's power literally everywhere. I'm intentionally not driving the M5 so that I don't end up getting it and blowing my budget. I have a few questions:
12-22-2019, 06:16 PM | #2 |
124
Rep 293
My previous car before getting a 2018 m550i was a TTRS and I also did not test drive it hard as well. When I first got the car, the only thing that disappointed me was just the handling which I assume will disappoint you as well if you've tracked the CTS-V. Honestly, my mom's cayenne handles much better than a stock m550i lol. BMW put really narrow 245 tires in the front of this super heavy 2000kg sedan for some reason. I highly suggest you fit much wider tires in front, like 275 or 265, and the grip will be as good as your CTS-V or maybe even better. Lowering the car also makes steering feel better but the most important upgrade is definitely front tires.
I am not sure about the turbos of the 2020 version so I cannot help you on that, I assume the engine is quite different since it makes way more power. Don't believe the people who say it's about the same power as the old engine, it definitely makes 10% more power both before and after any tunes. All I know is that the pre-2020 engine has no turbo lag above 2500 ish rpm. For exhaust, your options are quite straight forward. The one resonator setup is quite respectable and i would not consider it quiet at all. If you want louder, you just remove the one resonator for cheap and you get more sound! |
12-26-2019, 07:11 PM | #4 | |
91
Rep 183
12-26-2019, 07:15 PM | #5 |
91
Rep 183
There was definitely some turbo lag on both '19 and '20 that I drove, especially when compared to the supercharged large displacement engines. Hopefully it is less in Sport and Sport Plus modes, and hopefully there will be something aftermarket to reduce the lag further.
12-26-2019, 10:48 PM | #6 | ||
124
Rep 293
12-27-2019, 01:10 PM | #7 | |
553
Rep 1,068
Drives: i5 M60, M5's, 535.335, M550i
2013 535i M, Carbon black 20' 6 M wheels, totaled.
2018 750M , 2013 M5 , Individual Silver, Bolt ons-Straight piped 2019 M550 686BK Black Chrome 20"wheels, filters, Evolve Stage 1, Res delete 2024 i5 M60 Cape York Green |
12-28-2019, 05:16 PM | #8 | |
Seeking mental floss
482
Rep 806
12-28-2019, 06:36 PM | #9 |
4492
Rep 7,535
Just a reminder...the sport & sport+modes aren't actually the cherry on top (they're more like the whipped cream the cherry sits on . )...remember that the transmission has an "extreme" sport mode that is initiated when you move the gear shift lever into the M/S gate and leave it there (not using the manual steptronic shifting).
This mode has a shift map that was designed to maximize the engine's power resources with longer shift patterns....so when you add this feature when using the sport or sport+ modes...you can should be able to squeeze a little bit more from the car's resources (tranny, engine, steering, suspension, & dampers).
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
12-30-2019, 07:39 PM | #10 | ||
91
Rep 183
Reason I didn't get M5 is because I wanted to keep the payments under $1K. After owning cars that were much more it felt like a responsible thing to do, especially after 2020 got 520HP. Quote:
12-31-2019, 07:44 AM | #11 |
482
Rep 806
I understand, did the same thing myself. The full M cars have M buttons where you can fully program engine, exhaust, transmision, and suspension modes which all activate with the touch of that one button. With the M550, you can program engine, exhaust, transmission and suspension changes to happen with the touch of the sport button, but you must also slip the shift lever to the left to get the most agressive map from the transmission. If you touch the button programmed to sport plus, and slip the lever to the left, I think you will find no turbo lag, and a very motivated machine with performance which is very impressive. Good luck with your purchase.
12-31-2019, 03:09 PM | #12 |
553
Rep 1,068
If you do need more power and punch just get a nice modest tune. I have Evolve stage 1 and it's big difference, I had the Dinan V2 and that was a great tool too. Nothing has the instant punch a supercharger gives you, but in sport plus with lever in sport mode like I said above it's prepped and spooled waiting for you to hit it. Probably 90% as quick to apply/punch you as your CTSV did. With your 2020 with power upped, you'll be happy, and if you tune you'll be surprised what a monster the car is.
01-01-2020, 01:52 AM | #13 | ||
152
Rep 221
01-01-2020, 03:05 PM | #14 | |
91
Rep 183
01-01-2020, 03:09 PM | #15 |
553
Rep 1,068
It takes 2-5 min to flash your own car. Ethernet cable and your laptop.
DME I've seen good feedback over the years and spoken with him, haven't personally used his tune in my new car or last M5, Or email Irman or Mateen at evolve. Check out Irman a vids in his M5 with his tune doing Vmax with the F90 M5. Great video, really accommodating to work with when they set me up with tune on this car.
