12-12-2019, 08:04 PM | #1 |
Rep 26
Misfire after new spark plugs
I was driving the freeway the other day and I get a sputtering and a check engine light lights up and I check everything and nothing seems broke. The car will idle and if I am soft on the gas I can change gears at lower RPMs and eventually get home limping. Its been parked and I use my other cars in the meantime. I did a little searching and though the spark plugs must be the culprit. So I get home from picking up some plugs and change them simple enough. I try to start it to take it for a test and it wont start. any clue what I must have done wrong?
I just got done putting in a new driveshaft and though the sputtering the other day was the guibo bolts coming undone.... thankfully that wasnt it. Anyways, thanks in advance.
07 E83 6MT
06 R50 Mini 04 R53 Mini Last edited by Camg816; 12-12-2019 at 10:05 PM.. |
12-12-2019, 11:59 PM | #2 |
MARANATHA!
12
Rep 20
If you have access to a diag/code scanner, I would definitely start there first and see which fault codes shows up.
If you don't have access to one, I would suggest the Creator C310...it's very affordable. https://www.amazon.com/Creator-C310-.../dp/B00VSYZ2NC |
12-13-2019, 03:26 PM | #3 |
Rep 26
When I had the issue on the freeway I had my scanner with me. I don't remember the exact number but it was a misfire. I'm thinking/hoping the coil packs just aren't seated all the way and I just need to push/ twist them on further.
12-15-2019, 04:07 PM | #4 |
Rep 26
Finally got time to mess with the coils. I got all the coil packs properly seated and all the connectors are tight and in all the way. Now it starts but it keeps throwing a P0302p code. I swapped another coil in its place and the misfire moved. So in update I have ordered a new coil.
chassis6560.00 |
