M57 Valve Cover Gasket DIY video
12-09-2019, 12:16 PM | #1 |
211
Rep 433
Here's a video a Yozh and I did on replacing the valve cover gasket on a 335d. Next weekend we will be doing a VCG on a 2012 x5d and if there's anything you guys want to see, comment below.
If you find the videos useful please like and subscribe
2012 X5d | Deleted & BRR Tuned | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Thread https://www.xbimmers.com/forums/show....php?t=1529213 |
12-11-2019, 12:16 AM | #6 |
87
Rep 369
While being at it and if you guys fine with sharing mileage numbers, you guys should absolutely check if your timing chain is stretched or not with this very inexpensive kit:
https://www.ebay.com/itm/Diesel-Engi...7/173486814695 It would be nice to see some different data and if the timing might be off... ??? |
12-13-2019, 12:15 AM | #8 |
870
Rep 2,615
We did check the timing of course. It was spot on. Also spot on from checking TestO parameters on crankshaft to camshaft sync. Did not check chain stretch as did not have pins to lock chain tensioner.
12-15-2019, 01:17 PM | #9 |
806
Rep 1,191
One thing that would be nice to add to the video is which technique you guys used to get the injectors out. Slide hammer with special nuts welded together?
12-15-2019, 05:16 PM | #10 |
211
Rep 433
We just did the VCG on my x5 last night and we showed the injector puller and offset bracket. I'll try to get the video uploaded by Friday
12-16-2019, 08:25 PM | #11 |
160
Rep 803
Can this can to crank sync be checked anytime with testo, where would I look for it? Thanks
01-03-2020, 12:39 AM | #13 |
870
Rep 2,615
Just added two digest videos of a valve cover replacement from beginning to the end on an X5. Not a lot of commentary but got some details on the vac line mess.
02-02-2020, 11:02 PM | #16 | |
Rep 62
Didn't look at timing chain but hoping it is good at its lower miles. |
02-04-2020, 10:27 PM | #19 |
Rep 62
I would say 100k unless you see signs of failure. My 2011 35d has 145k with no issues. I should probably do that one soon.... not sure the VCG was the issue with the 335d. It is still smoking and saw a small puddle of oil again. I will pull the covers soon and see if it's leaking around turbos or still the rear main. Waiting for Yohz to post a vid of a complete overhaul...
02-04-2020, 11:49 PM | #20 | |
671
Rep 1,442
