12-01-2019, 09:23 AM | #1 |
53
Rep 251
335d engine oil leak?.....
I noticed a small oil patch on my friends driveway. I looked directly above it and noticed some small drips coming from my car. I have attached some pictures of the area the oil was found and have noticed there is an oil cooler in the vicinity. Has anyone else had a similar issue?
12-01-2019, 10:12 AM | #2 |
Old Fart
361
Rep 694
There is indeed the engine oil cooler mounted in that area but the problem with modern cars is that there is an undertray for the engine bay which means the oil could be leaking literally anywhere on the engine and finding it's way out there if that is the lowest point when you were parked.
Can you see anything when looking down into the engine bay? You might be able to see the undertray from above....
The doctors said it's OK to listen to the voices..... just don't do what they tell me
12-01-2019, 01:32 PM | #6 |
659
Rep 1,239
Highly doubt it is the gearbox, no where near there. Being a UK car i dont think we got a gearbox oil cooler? There is a slight chance it could be the small oil cooler, hit by a stone/rock and causing the leak? Do the new age 335'd suffer from the red boost pipe seal issue? Quick check would be to take the airbox out and have a look down.
Go's with out saying, keep an eye on the engine oil |
12-01-2019, 01:49 PM | #7 | |
840
Rep 1,993
Drives: F30 335d
if I've helped - an Appreciate would be, er, very appreciated!
12-01-2019, 02:00 PM | #8 | |
659
Rep 1,239
As per my above comment about that rad in the side it should be coolant and not oil so ignore that brain fart moment. |
12-01-2019, 02:44 PM | #10 |
53
Rep 251
12-05-2019, 05:56 AM | #11 |
470
Rep 786
Drives: 2018 F80 M3 CP YMB
Certainly on older 35d the hose to the oil cooler is known to weep/fail - I had that at around 100k once...
Current: 2018 F80 M3CP YMB. Previous: 2015: F34 335d GT M Sport+; 2012: F07 535d GT M Sport; 2008: 335d SE; 2005: 530d; 2003: 330d; 2002: 330i; 1999: 523i
12-05-2019, 06:42 AM | #12 |
142
Rep 342
Coming from that side at the front its almost certain to be the seal on the "red pipe" i.e. the boost pipe from the turbo to the intercooler. Very common for these to leak a little as time goes on and oil to seep down into the plastic undertray and then onto the deck. Not a big or expensive job to rectify, just fiddly due to tight spaces. Have a good look around for videos and relevant posts that will help.
12-05-2019, 07:59 AM | #13 | |
840
Rep 1,993
Drives: F30 335d
But the 'red pipe' was on the M57 engined E9x
12-06-2019, 03:21 AM | #14 | |
53
Rep 251
12-06-2019, 03:24 AM | #15 | ||
53
Rep 251
I need to get it checked out while it's still under warranty. |
12-06-2019, 03:27 AM | #16 | |||
53
Rep 251
12-06-2019, 03:28 AM | #17 | ||
53
Rep 251
12-06-2019, 04:01 AM | #19 |
840
Rep 1,993
Drives: F30 335d
Engine code is N57D30T1
The intercooler will contain oil from the oil vapours coming from the CCV - crankcase ventilation, there is a pipe going from the rocker cover to the main intake pipe between the maf/airbox and turbo. The turbo draws a combination of fresh air and this vapour.
CuntFace500053.00 |
12-08-2019, 02:53 PM | #20 | |
Old Fart
361
Rep 694
BTW, if the oil is black it's engine, if it's red then either power steering or gearbox.
12-08-2019, 04:49 PM | #22 | |
6428
Rep 8,502
The turbo doesn't draw air from the IC. The IC is downstream of the turbo and cools charge air after it's been pressurised.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
