Crazy for considering replacing swirl flap seals instead of blocking?
11-21-2019, 08:43 AM | #1 |
260
Rep 714
As the title says, I'm considering replacing my swirl flap seals, to stem the leaking I have from there. Am I crazy? They're there apparently for low load efficiency, and that does really matter to me. a .5-1 mpg drop would be enough for me to replace the seals and keep them.
Does anyone see a drop, that truly tracks their mileage? I track every single mile on fuelly, and drive 40k miles a year right now. I tow a numch too, but I assume even towing at cruise isn't considered "low load," and therefore I'm not that worried about towing mileage changing. |
11-21-2019, 12:18 PM | #3 |
160
Rep 803
I think the only time they help is when you still have regen and egr. When the egr is being used, the mixture is not as lean, so having swirl evens out the combustion at slow speeds. This helps reduce soot build up in the dpf, making it need less regen.
Without egr, there's already a huge excess of air (oxygen) and the burn is fine. Removing the flaps didn't affect the mileage of egr/dpf deleted cars from what I understand. It does effect those who still are stock. |
Persian Whisperjet166.50 |
11-21-2019, 01:07 PM | #4 | ||
260
Rep 714
11-22-2019, 05:30 AM | #7 |
Kind of a Big Deal
167
Rep 857
I too had questions, but I did it at 70K and have zero zero change in mileage over the past 65K miles.
11-22-2019, 07:12 AM | #8 |
260
Rep 714
Always, I looked yesterday. #2 would be the seals, wouldn't they? Am I crazy?
https://www.realoem.com/bmw/enUS/sho...diagId=11_3876 |
11-22-2019, 07:15 AM | #9 | |
277
Rep 1,575
11-22-2019, 07:15 AM | #10 | |
260
Rep 714
Good to hear. I'll likely just sold the prblem and block them off then, but I'm still undecided. |
12-04-2019, 05:01 PM | #11 |
3058
Rep 3,910
You probably won't see any change in fuel consumption from removing the flaps, but what you might notice is a drop in low RPM torque/power.
The swirl flaps are there not to restrict air flow into the cylinder, or to affect the AFR; they increase the velocity of the air entering the combustion chamber, which increases turbulence in the chamber, which in turn aids combustion by dispersing injected fuel faster - this is important when you have small amounts of fuel being injected (short injection duration, low injection pressure). The resulting burn will be cleaner with them, but I doubt you'd need to worry about dpf or egr if you remove the flaps. Of course, if your car is an auto, you'll probably notice no difference at all. I had a poor attempt at sealing mine with PU sealant last year...they're still leaking now. I think I could do it better, but I'm trying to think of other options for renewing the whole assembly rather than patching them up again. I don't want to fork out hundreds for a whole new manifold, and I don't want to remove the flaps! |
robnitro160.00 Persian Whisperjet166.50 |
12-22-2019, 06:49 PM | #18 |
Rep 3
I've had my swirl flaps deleted at 117k miles. The flaps looked to be in pretty bad shape so I'm glad I deleted them when I did. I've noticed no change in MPG or performance (some people claim a drop in low end torque)
