Bimmerpost
4 Series
Technical Topics Wheels and Tires Steering with Michelin A/S 3+
      11-20-2019, 09:58 PM   #1
Gman1
Drives: 2016 435i xdrive
Hello all, I drive a 2020 M340i xdrive. The car is beautiful in so many ways and is a definite improvement over my old 435i in every aspect. The only thing that bothered me was the tires that they came with as standard. They came with pirelli p7 cinturato runflats and they felt like the car was riding on wood. They were surprisingly comfortable, but had no grip, and you could tell that by going on a semi-spirited drive. I did my research on good all season non runflats that are performance oriented and found that most people seemed to be impressed by the Michelin A/S 3+ tires. I ordered a set and had them installed yesterday.
I found that they impacted the steering in a really significant way. The steering is no longer as direct as it was with the runflats and its not nearly as heavy in sport mode. The heaviness doesnt bother me too much, as its pretty artificial, but I am bothered that it isnt as direct as it once was. The tires themselves are good, I definitely notice the extra grip, but I was surprised how they affected the steering. Has anyone else had this experience? Changing the stock run flats with non runflats and finding that the steering is now not as precise? I assume it has to do with the softer side walls.
THE3285.50
      11-20-2019, 10:04 PM   #2
RedKloud
RedKloud's Avatar
736
Drives: BMW i4 M50
I had the same experience with A/S 3+ tires on my F30. I think you do lose some of the steering feel because of softer sidewalls on the non RFTs.
I wonder how is the feel on cars that come with non RFTs performance tires from the factory. Is the steering tuned differently in some way for non RFTs on these cars?
      11-20-2019, 10:05 PM   #3
Patgilm
181
Drives: GT-R, X7 M50i, M340
Uh oh, I will find out after this weekend but I am getting Conti Extreme Contact DSW’s installed. I figured it wouldn’t handle as well as my run flat summer tires I have on there now but was hoping it wouldn’t be too bad and would be more comfortable.
      11-20-2019, 10:06 PM   #4
RedKloud
RedKloud's Avatar
736
Drives: BMW i4 M50
Conti DSWs reportedly have even more softer sidewalls than the A/S 3s.
      11-20-2019, 10:42 PM   #5
Patgilm
181
I know, I considered getting the A/S3s for that very reason but I really liked how my DSWs handled in bad weather in the past and I didn’t want to give that up based on my prior experience with the tire.
      11-21-2019, 08:57 AM   #6
NeroCCC
Drives: 2020 M340 Xdrive
I have P0(20'') on my summer set, I then switched my winter set recently. I am running this A/S 3+ as my winter tire(down to 19''). So far, I feel it is pretty identical to my P0. Just bit softer and lighter steering wheel feel.
      11-21-2019, 10:57 AM   #7
Prissy
Prissy's Avatar
Taiwan
1069
Drives: M340i
2015 BMW F30  [5.50]
2020 M340I  [0.00]
2017 X3  [0.00]
2008 BMW E92  [9.00]
2010 BMW E92  [10.00]
have you guys tried this one?
https://www.tirerack.com/tires/tires...!&gclsrc=aw.ds
      11-21-2019, 12:03 PM   #8
Jbrock22
Jbrock22's Avatar
222
Drives: 2pw
BMW   [0.00]
Run flats often have an initial better turn in because of the stiffer sidewall. To compensate add another 1-2 psi. This should mitigate the issue.
      11-21-2019, 05:52 PM   #9
Gman1
Okay, so you recommend to add a bit of pressure to regain the steering precision?
      11-21-2019, 06:49 PM   #10
Jbrock22
Jbrock22's Avatar
222
Drives: 2pw
BMW   [0.00]
Yes that's what I did on my 2016 340i. I switched from Bridgestone S001 RFT to the Pilot Sport AS3+.
After a few miles you will get used to the different feel, you will never miss the RFT.
Current car M340ix, my summers are PPS 4s go flats. Winters are Pirelli Sottozero 3 go flat. I'm running 39PSI all around. That's what the manual recommends.
      11-21-2019, 07:28 PM   #11
RedKloud
RedKloud's Avatar
736
Drives: BMW i4 M50
39 PSI all around even for staggered setup?
      11-21-2019, 08:46 PM   #12
Jbrock22
Jbrock22's Avatar
222
Drives: 2pw
BMW   [0.00]
Winter 225/45/18 square, owners manual says 39psi.
RedKloud736.00
      11-23-2019, 04:05 PM   #13
Patgilm
181
Had my Conti’s installed today. Little bit of a difference in steering but it doesn’t bother me as it actually rides better with my new tires so it’s a little bit of a trade off. However, I haven’t had a real chance to drive it hard yet so once I do maybe I will feel different.
      11-25-2019, 02:02 PM   #14
RedKloud
RedKloud's Avatar
736
Drives: BMW i4 M50
I am going to get A/S 3+ installed next week as well. I wonder what would be the ideal pressures for non-RFTs. People with Pilot Super Sports 4 - what pressures are you running?
      11-27-2019, 07:06 PM   #15
iwantanm4too
Drives: No car
You may wanna try adjusting tire settings in your vehicle status. Change it from summer to "Winter/All-season". I found that it helps, and it gives you optimal tire PSI suggestions for the temp.
      12-02-2019, 06:21 PM   #16
RedKloud
RedKloud's Avatar
736
Drives: BMW i4 M50
Taking the car in to get A/S 3+s installed tomorrow!
      12-02-2019, 08:07 PM   #17
WXdrivefun
WXdrivefun's Avatar
285
Drives: G20 330Xdrive
If you are referring to Pilot Sport 4s summer tires, 35 PSI in front 38 PSI in the rear. (Staggered configuration). The pressure ratings are on the nameplate when you open the door, remember this is done at cold temps.
      04-24-2021, 03:40 PM   #18
GrubTheHedgehog
43
Drives: M
How did you like the A/S 3+ on your car?
      04-24-2021, 04:30 PM   #19
RedKloud
RedKloud's Avatar
736
Drives: BMW i4 M50
They perform well for an AS tire - no complaints. The steering feel is better with RFTs though.
      04-25-2021, 10:01 AM   #20
jeegunkim
jeegunkim's Avatar
328
Drives: 2020 330i xDrive, 2023 M3CX
I just installed the A/S 3+ and can confirm that it does impact the overall steering feel.
I'm on an xDrive and it came from the dealer with a square setup with Pirelli Cinturato P7 all season run flats. Was not thrilled about them, grip was adequate at best, I could not stand the amount of tire noise while driving. It did perform okay during nominal weather conditions though.
I recently upgraded my suspension, wheels/tires. Running a staggered setup with 19x9.5 +22 and 19x10.5 +35 with the A/S 3+. Such a night and day difference, the A/S 3+ performs better than some summer tires I've had before and with the wider setup, lower suspension, it really improved the overall handling and ride quality. The downside is that like this thread mentions, you do lose steering feel. I didn't mind losing the steering feedback but what bothers me is how much lighter the steering is now. I love weighted steering feel which was OK on the stock setup but with this new setup, even in Sport Plus, the steering has definitely lost its weight which really bothers me. I'm just trying to rationalize it in my head that the benefits I am getting with the new setup outweighs the loss of the steering weight, haha.
2020 MG 330i xDrive M Sport
2023 AR M3 Competition M xDrive
THE3285.50
      05-18-2021, 08:03 PM   #21
Antec800
128
Drives: 340i x drive
You also need to wait for the tires to break in and they lose a bit of tread to feel better
      05-18-2021, 10:01 PM   #22
pneumodoc
pneumodoc's Avatar
233
Drives: G20, G01
What about road noise? How is that by comparison?
g20
