F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > CEL on with downpipe/JB4
proTUNING Freaks
      11-14-2019, 08:45 AM   #1
ZZ-mtl
ZZ-mtl's Avatar
Drives: BMW
Unhappy CEL on with downpipe/JB4
Hey guys looking for some help here... I did a catted downpipe install with JB4 at a local shop a couple months ago. Everything seems just fine until the check engine light came on last night.
Is there any way to tell if this is due to the downpipe install or some real issue with engine?
I went to the shop just now but this is a tire change season so they need me to book an appointment... Just don't have resources to check this out at the moment. I was going through forums looks like with JB4 and downpipe, if I go to BMW they won't be able to diagnose (until JB4 is disabled or set to map0?)
      11-14-2019, 01:51 PM   #2
Mike@N54Tuning.com
BimmerPost Supporting Vendor
4920
Drives: 2007 335i, 2015 M3
Scan the code with the JB4.. It has a built in code scanner.
Mike
      11-14-2019, 06:52 PM   #3
ZZ-mtl
ZZ-mtl's Avatar
Drives: BMW
Mike
Thanks Mike! All set
      11-14-2019, 07:45 PM   #4
Fuel-It!
550
Drives: M4, M5, M2C, X4M, 440i, etc...
For DP code outside USA you have passive delete option on WMI page, it's blocked in the USA but in Canada should show for you.
      11-16-2019, 03:34 PM   #5
ZZ-mtl
ZZ-mtl's Avatar
Drives: BMW
Thank you! They called me back and did a quick scan, turned out it was the DP.
Is this scan something I can do myself in the future or always need to go to the mechanic?
      11-18-2019, 12:14 PM   #6
Fuel-It!
550
You read codes in the JB4 app under "fault codes".
f30post
