Bimmerpost
4 Series
Technical Topics B48 4-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications 330e with 403HP. Does it make sense?
      11-13-2019, 11:28 AM   #1
eddiehaug
eddiehaug's Avatar
Norway
743
Drives: i4M50
2023 BMW i4M50  [0.00]
I've just seen this on Instagram and I wonder whether this even makes sense. Can the car eventually handle those 400HP without extra modifications to the chassis or other components?
Current BMW: i4M50 (G26, 2023)
Previous BMWs: 330e Touring xDrive (G21, 2021), 330e (G20, 2019), 530e (G30, 2018).
      11-14-2019, 03:18 AM   #2
A6bullet
Germany
336
Drives: 2020 330i Msport
SEND IT
      11-14-2019, 04:23 AM   #3
Oski666
Drives: Bmw G20 330i Msport
LOL this is inaccurate..I would not call it a fake, but they probably sum up the power of electric accumulator + engine map...that is the result
      11-19-2019, 11:18 AM   #4
BMW 330E M-Performance
Sweden
49
Drives: BMW i4
I mail them for my car they have 340 hp
I have the B48 B20A engine but if you have the B48 B20B you make over 400 hp to the 330e its same like 330i + electric
      11-19-2019, 03:15 PM   #5
dejansokolovski
78
Drives: BMW 330e G20, BMW 520D F11
Why does BMW have two different A and B models for the 330e? And what kind of lottery is it not knowing which one you'll end up with? :O
I can imagine USA market or somewhere non-EU has the B-version while us in Europe have A-version, I can't imagine that I would for example possibly have the B-version while you would have the A-version when both of us are in Sweden/EU...?
How did you/them find out which one you got btw? I've tried looking it up through VIN number et.c but couldn't see anything stating if it was A or B version..
      11-20-2019, 02:18 PM   #6
Sweden
49
Drives: BMW i4
dejansokolovski Biluppgifter.se Logga in o kolla kan gissa på att vi har samma..Tyvärr
      11-20-2019, 04:55 PM   #7
dejansokolovski
78
Ah fan det stämmer, står att jag också har A-versionen.. men fattar inte, vill minnas att jag såg B någonstans. Var kan man mer kolla upp motorkod?
      11-21-2019, 03:14 AM   #8
A6bullet
Germany
336
I believe its dictated by what trim you go for.
Anything less than a 330i youll get the weaker A version. If its the 300i youll get the B version.
That's from my limited research.
E36 318ti
E46 320i
E82 135i
F87 M2
G20 330i
      11-21-2019, 09:24 AM   #9
-Nick
-Nick's Avatar
83
Drives: G20 330e
I don't think this combination exists?
As all 330e's use the same B48 B20A (182bhp) petrol engine.
Only the 330i has the B48 B20B (254bhp) petrol engine
      11-22-2019, 03:51 PM   #10
Sweden
49
Drives: BMW i4
I was to my chiptuning friend here in sweden we try to chip the car , big diffrence on the petrol engine about 270-280 hp but the electric did not work togheter
we dont know what the problem was.. so now its original again.
Time to se if other can fix this :/
      11-22-2019, 04:05 PM   #11
bimmer456
2940
Drives: 340i
They ought to put the i8 engine and electric motor in there. And make it x drive.
      12-05-2019, 02:38 PM   #12
Sweden
49
Drives: BMW i4
dejansokolovski
Nytt trimm på BSR min va tydligen b48b20B
https://sv.bsr.se/trimsatser/t/4409/...2020-b48-b20-b
Hör med dom
      01-12-2020, 05:18 AM   #13
svanis115
Drives: BMW 330e
dejansokolovski
Hör med dom
Vilken modell stod det att du hade när du kollade på biluppgifter? har kikat runt lite på olika reg och ej hittat ngn som visar B
/svanis
      01-12-2020, 06:56 AM   #14
sspdw
71
Drives: bmw m140
/svanis
Hur mycket ger bensinmotorn? 326hk om jag förstått det rätt?
      01-12-2020, 02:32 PM   #15
Icemachineboss
Drives: 330e G20
330e Boost
Hej
Jag har varit hos BSR och chippat bilen. Den går som fan nu !
      01-12-2020, 05:08 PM   #16
dejansokolovski
78
/svanis
Det var på meca.se som motorkoden står, välj som privatperson osv..
Tror inte det är 326hk riktigt.. sen är ju elmotorn på totalt 114hk också. Men man kan väll inte bara plussa på de siffrorna heller för att få en totaleffekt? Hur som helst är det imponerande effektökning i alla fall! Vill verkligen se riktiga tider uppmätta..
      01-13-2020, 09:15 AM   #17
SteveinArizona
3086
Drives: BMW 530e
Correct. You can't just add the two together. For one thing, the electric motor takes the place of the torque converter. Some car companies do just add them together but they are misleading the buying public.
      01-14-2020, 02:24 PM   #18
Sweden
49
Drives: BMW i4
@ Icemachineboss Visst är det sjuk skillnad är supernöjd med min !
      05-04-2020, 02:56 PM   #19
svanis115
Drives: BMW 330e
Någon här som befinner sig i Stockholm? Skulle vara guld värt att få uppleva skillnaden innan beslut tas. Bjuder självklart på lunch/ önskad fika... nya bakdäck😁 som tack
      06-29-2020, 03:25 AM   #20
BelfastCol
Drives: G20 330e M-Sport Plus
Wrong my friend. Some 330e's have the A and some the B.
I have the B in mine.
      06-29-2020, 06:43 PM   #21
joselrl
Portugal
33
Drives: BMW G20 330e 2019
How do you find out which one you have? Is it labeled somewhere?
      07-04-2020, 04:41 PM   #22
eddiehaug
eddiehaug's Avatar
Norway
743
Drives: i4M50
Check here: https://bimmercat.com/
Mine was produced in 11/2019 and I have the B.
Search this Thread:
Advanced Search
g20
