Excessive vibration at idle(no codes)
11-12-2019, 10:07 PM | #1 |
234
Rep 990
Hey, guys, thank you very much first off all for being there whenever help is needed. While I do know this is an e90 post, I do apologize in advance as my car is e70 x5 35D. This is just a more active section so I figured I’d try my luck here(mods please forgive me 0 ). I have a 2012 35D with 92xxx miles and had this car since 84k and it always had this weird issue of excessive vibration at idle with no codes. Once I start driving it goes away, every time I stop(doesn’t matter P or D) it comes back. I can feel it in the pedal and steering wheel. I remember reading somewhere that the motor mounts are vacuum controlled(?) and there’s a TIS to reprogrammed the module which gets stuck in highway mode causing excessive vibration, but not really sure if that’s the case and can’t find that thread. So here I am. Thank you for your help!
2010 Alpine White E90 335i RWD 6MT M/Premium/Cold
11-12-2019, 10:11 PM | #2 |
Rep 7
I mean, there's a very very small chance that it's that... But theres a way bigger chance that your harmonic balancer is beginning to fall and the rubber is separating. My car did it at the same mileage just about, if it is, it's not really that hard of a job to do yourself. And if you can afford it, get the upgraded fluidampr kit and you'll never have to do it again.. just look into the engine bay, if it smells like rubber at all or if you feel the rubber is separating in the balancer that very well could be it.
Also check your exhaust mounts, my cars pretty slammed and I'm constantly flighting my rubber hangers moving and shifting. It may shake excessively at idle or even be rubbing. |
11-13-2019, 03:43 AM | #3 | |
277
Rep 1,575
11-13-2019, 11:35 AM | #6 |
274
Rep 1,054
That's what I have ^
I agree with everyone else sounds like HD you'll be amazed at how many vibrations go away. My entire dash use to vibrate in my 335d. Also while you're in there I would also do clutched alternator pulley, thermostat, water pump, and both belts
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R. |
11-13-2019, 11:43 AM | #7 |
274
Rep 1,054
the vibrations smooth out naturally as you go up in rpm meaning the HD doesn't have to dampen as much. So it can still be the HD
11-15-2019, 08:44 AM | #8 |
910
Rep 2,091
I have this same issue, a very light steering wheel vibration when stopped in drive. Ill take a look at the balancer.
MGM F82 M4 DCT / MPerformance / Swift / CSF / IND / Turner / BimmerWorld
BSM F87 M2 6MT / Fabspeed / MPerformance / Turner / AutoID - SOLD JB-NB E92 M3 6MT / IND / RTD / Alpine / KW / ActiveAutowerke / 360Carbon - SOLD SS2-FR E90 M3 6MT / IND / AFE / ActiveAutowerke - SOLD AW-FR E90 M3 DCT / ACM / IND / AutoTecknic / K&N / H&R / Bilstein - SOLD |
12-14-2019, 06:35 PM | #13 |
Rep 35
Motor mounts contain rubber. Rubber, especially as it gets older and starts to degrade, gets really hard when it turns colder.
My 335D got steering wheel vibrations in idle about this time last year. New motor mounts cleared the vibration right up.
JR 2.8; Sutphin trans tune; ATM intake, IC, DP, & straight pipes; Fluidampr HB; AARod race pipe; swirl flap delete; Bilstein B12 Pro-kit, M3 control arms
