The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > 4560 4570 Rail pressure plausibility quantitative control
      10-23-2019, 10:09 AM   #1
Torgus
Slow.
Torgus's Avatar
3782
Drives: Single Turbo N54 on Meth!
2007 BMW E92  [10.00]
2007 BMW E90  [0.00]
2006 BMW E91  [0.00]
I keep getting:
Fault Code: 004560
Fault Explanation: Rail pressure plausibility quantitative control
Fault Code: 004570
After the car warms up and under 1/2 throttle.
Any chance it could be tune related?
Would you start with a HPFP or The rail sensor? If HPFP I assume I should upgrade to the R90 because why not?
My fuel filter has less than 5k miles on it.
Appreciate the help guys! Thanks in advance.
      10-24-2019, 09:25 AM   #2
Yozh
Yozh's Avatar
No_Country
870
Drives: 2011 335d M-Sport
What you should start with is logging all the related fuelling parameters. Unless you need an excuse the start throwing parts at your car just to find out it was one of your injectors.
      10-24-2019, 09:59 AM   #3
Torgus
Slow.
Torgus's Avatar
3782
2007 BMW E90  [0.00]
2006 BMW E91  [0.00]
Thank you for the advice. I don't think I have software to do that unless carly can.
Both lpfps are new thanks bmw.
I can't imagine there is much else to cause low fuel hp rail pressure other than the hpfp or sensor?
Could a bag injector dumping fuel do it?
      10-25-2019, 02:08 AM   #4
Yozh
Yozh's Avatar
No_Country
870
You’ve got HPFP, flow control valve, all six injectors, return line with restrictor, rail sensor and rail regulator. Injectors can cause rail issues as well. Expensive to shoot in the dark in this case.
      10-25-2019, 06:33 AM   #5
Torgus
Slow.
Torgus's Avatar
3782
2007 BMW E90  [0.00]
2006 BMW E91  [0.00]
Ok thank you very much.
What would I use to log? I am guessing it will help narrow down the issue? My car is at a bmw mechanic right now. I would be happy to give them a hint or direction on what to do before blindly replacing parts
      10-26-2019, 12:33 AM   #6
Yozh
Yozh's Avatar
No_Country
870
Use TestO it’s free.
      11-13-2019, 09:50 PM   #7
Torgus
Slow.
Torgus's Avatar
3782
2007 BMW E90  [0.00]
2006 BMW E91  [0.00]
New HPFP fixed my issues. No more codes.
      11-14-2019, 10:36 PM   #8
Yozh
Yozh's Avatar
No_Country
870
Was a new flow control valve fitted with that new hpfp? And adaptations were reset?
      12-05-2019, 02:15 PM   #9
Chief Orman
Chief Orman's Avatar
671
Drives: 335D 2010
Originally Posted by Torgus View Post
I keep getting:
Fault Code: 004560
Fault Code: 004570
Did you end up swapping out your fuel rail sensor too?
      12-05-2019, 02:38 PM   #10
Torgus
Slow.
Torgus's Avatar
3782
2007 BMW E90  [0.00]
2006 BMW E91  [0.00]
I will ask I did not do the work myself this time. AFAIK it was just a new HPFP and adaptations.
That was already done and did not help. But it seemed like a good idea which is why I did it before I dropped the coin on the HPFP.
      12-06-2019, 07:47 PM   #11
Papogator24
19
Drives: BMW X5 3.5i
Did you get a R90?
2013 X5 35i
2011 335d - Deleted and Tuned by BRR
2008 Toyota Tundra SR5 Double Cab
Torgus3781.50
      06-18-2020, 01:10 PM   #12
alfaivre
Drives: 2011 335d
Same issues on hot track days
I received the same codes and a few more yesterday while on the track. I would say I received that after wide open throttle on the straights. Locally it was close to 90F ambient, coolant temps reached about 225F. It eventually shutdown the engine. Wondering if it is all heat related and a safety mechanism. I am tuned. I have only seen these while on the track, otherwise I am fault free.
Fault Code: 004560 / not present
Fault Explanation: Rail pressure plausibility quantitative delivery controlled
Fault Code: 004570 / not present
I am also getting:
Fault Code: 004610 / not present
Fault Explanation: DDE: Rail pressure plausibility pressure controlled
Fault code: 651 B/ not present
Fault Explanation: EKPS: Suction-jet pump function faulty
Looking at my torque log, the Fuel Rate (direct from ECU)(L/m) seems to spike looks like 59-81L/m when the motor shuts off. If I turn off / turn back on the ignition while rolling in nuetral the engine will restart.
      06-18-2020, 02:13 PM   #13
Torgus
Slow.
Torgus's Avatar
3782
2007 BMW E90  [0.00]
2006 BMW E91  [0.00]
Originally Posted by Papogator24 View Post
Did you get a R90?
No, I should have looking back on it I guess not much more. But I never will put hybrids on this SAV so it wouldn't help me I don't believe.
Next is a 6.7L Cummins for me. Time to make some big boi tq! I promised myself i would hit 200k before i sold it and got the truck. Working from home I have been stuck at 150k for a LONG time. Going to take ages to hit 200k.
      07-29-2020, 11:03 AM   #14
e70x5d
Drives: e70 x5
Sorry fo thread jacking needed to make a 1st post. My 11, 125k mile ,BRR tuned /deleted x5d has been going into reduced power, and coming up with 4560 4570 p0087 in these hot humid summer days as of late.
New fuel filter, all recommended maintenance has been done( vcg, silicone lines, all cbu cleaning, etc etc). My problem is mainly when in low rpm and applying throttle, start seeing a plume of coal from the rear, and car feels like its struggling. ive done some data logging with test0 , anyone care to look at my logs to see whats up?
      08-07-2020, 03:32 PM   #15
Bumcheese
Bumcheese's Avatar
Drives: e93
Same 02 errors 004560 and 004570 on e93 last evening. Car was idling for more than an hour with aircon ON when the fault code came up. Its driving though with significant engine power reduction and has the same message on the dashboard. Cleared the codes twice using Carly but the error/fault came back on. I am attaching the live values taken at the time. Would be grateful if any one can point to the specific issue. Thnx
[IMG][/IMG]
      06-05-2023, 04:50 AM   #16
335dlci
277
Drives: 335d
Originally Posted by sonaxarrell View Post
Last night on e93, the same 02 faults 004560 and 004570 appeared. When the fault code appeared, the air conditioning system had been running for more than an hour. With a major engine power loss, it is currently driving while displaying the same notice on the dashboard. Carly was used to clear the codes twice, but the fault or issue kept returning. The current values that were taken at the time are attached. I'd appreciate it if someone could identify the precise problem.
Why would you just clear them? Then clear them again and then think "hey this isn't fixing , isn't it.. maybe I should annoy the group.."
      07-14-2023, 12:04 PM   #17
Asonchadwick
Sleepy
75
Drives: bmw
Has anyone here checked their ekpm module? I also have these codes sometimes under wot but I discovered my lpfp was not supplying the fuel needed. No codes either and ekpm seemed to be working fine except it wasnt.
      10-09-2023, 01:40 AM   #18
Opsudya
Drives: life
Originally Posted by Asonchadwick View Post
Has anyone here checked their ekpm module? I also have these codes sometimes under wot but I discovered my lpfp was not supplying the fuel needed drift boss. No codes either and ekpm seemed to be working fine except it wasnt.
Have you fixed this problem yet?
      11-06-2023, 10:51 PM   #19
marryjoy6374
Drives: Ford F-150
Wishing whoever
I want to remind everyone to go to bed early, going to bed early helps you have a new day full of energy, you still want to play but your brain and body need to rest heardle
      04-16-2024, 03:17 AM   #20
e91330d
Drives: bmw e90 330d
I am also getting:
Any insight on this? I've got a very similar issue, when giving WOT its asking for 1300 bar but only get 800 ish and can't keep up
      04-16-2024, 08:04 AM   #21
maryjane
95
Drives: 2011 335d Msport 3 Snail.
rail codes
What tune? Did you recently upgrade? Here's a list of stuff to check.
1 check fuel filter
2 metering valve on back of hpfp
3 pressure control valve on rear of fuel rail
4 injector failure
5 hpfp failure
