10-15-2019, 09:07 PM | #1 |
BMW owner
66
Rep 56
Drives: BMW X5 xDrive40i
19" or 20" wheels ?
I'm considering getting the 19 inch wheels because ride comfort over pot-holed roads is more important to me than stylish wheel rims. But I really dislike the Style 734 wheels that BMW offers on the X5 at 19".
Would it be possible to order the vehicle with 20" wheels, Style 738, then toss out the original tires onto ebay, and replace the tires with non-low-profile tires (with taller sidewalls)? Or will that cause problems that my ignorance cannot foresee? If its OK, then the same question also for 21" wheels. |
10-15-2019, 11:04 PM | #2 |
1698
Rep 2,609
As a default approach, whatever changes you make from stock, you'll want to achieve about the same overall circumference as stock for both proper fit in the wheel well and speedometer accuracy. In that context, you generally cannot get a taller sidewall profile on the same size rim diameter — you need less rim if you want more rubber, so you need to go down to 19" to get taller sidewall.
In some cases, it may be possible to put a narrower tire on the same rim and that may allow taller sidewall. However, this is an advanced topic and it doesn't sound like you should be considering this right now without a competent advisor on speed dial :-). If you are going into after market rims, that's a whole new game of bolt patterns, offsets, hub diameters and centricity, possibly spacers, hub adapters, lug bolt shapes and lengths, etc. A shop that you can trust is best approach unless you're willing to immerse yourself and do some trials. Also note that M Sport brakes generally don't fit 19" wheels, 20" and up only. To get your head into this, spend some time at the links below and play with options. https://www.wheel-size.com/size/bmw/x5/2019/ https://www.wheel-size.com/calc/
G05 X5 x40i (04/2019 mfg, Canada) on S18A-19-11-540
10-17-2019, 01:28 AM | #3 |
BMW owner
66
Rep 56
Thanks. That’s very helpful.
It looks like I’ll go the After Market route with 19” rims. |
11-22-2019, 02:42 PM | #5 |
Owner
132
Rep 566
Drives: G05 30d M-Sport
UK back roads are particularly bad, and I feel the M-sport with the standard 20" works very well. I have 275/45/20 and 305/40/20 I think, P-zeroes, and had no problem with them at all -- even off road so far (light off road!).
20" still look reasonably 'badass' without sacrificing ride quality. I do have air suspensions tho...
Received 190911: X5 30d M-Sport:Artic Grey:Comfort Pack:Tech Pack:Visibility Pack: Driver Assist Pro Pack:Heat Pack:Glass Roof:Leather Dash
11-22-2019, 02:56 PM | #6 |
BMW owner
66
Rep 56
I did end up going with 20” because I liked the rims so much better than the 19”.
And I ordered the Air Suspension, too. It’ll be fine; I was just stressing. |
11-30-2019, 03:17 PM | #7 |
Rep 16
We have bad roads here in NY and I'm tired of dealing with popped tires and bent wheels. I ordered mine w 19" wheel and suspension - I love the ride. I'm getting old!
11-30-2019, 03:36 PM | #8 |
30
Rep 116
Also NYC based. I hit a bad pothole once when I had sport tires on my Infiniti G37 and developed a big air bubble in the sidewall of the tire... was told it was no longer safe to drive. I transferred onto my winter tires for that car for the last month of the lease 🤣
I’m also planning to stick with the standard 19” wheel and suspension... I agree that the 20’s do look better but I’d rather the more durable option this time around.. |
12-23-2019, 08:59 AM | #9 |
55
Rep 120
I'm Chicago based. Get the 20" and replace the run flats with Michelin cross climate suv tires from tire rack. They're amaZing. Far superior to the OEM and much more traction.
polychromatic134.50 matthew_hull65.50 |
01-29-2020, 01:45 PM | #10 | |
26
Rep 69
Appreciate your thoughts! |
12-29-2020, 06:17 PM | #11 | |
2366
Rep 2,620
Mostly, it was my experience with my previous Cayenne S with the 21 or 22-inch rims with Summer tires that was a nightmare with curb rashes and pretty much useless in snow and heavy rain. For a daily driver, I promised never again. For me, the biggest sacrifice with the 19 inches isn't the aesthetics but not being able to get the sport brakes with its smaller rim. But no regrets overall since the ride is so much better. I do have the air suspension, but the bigger side walls make a real difference. I guess it boils down to how you use the car. |
12-29-2020, 10:44 PM | #12 |
3153
Rep 6,789
Personally, I could care less what other people think of the looks of my vehicle. You cannot see the color if you're watching where you're going, or the wheels from the driver's position. The parts I can see while in it are important. Yes, bigger wheels with lower profile tires have the potential of better handling, but really, how many people actually push their vehicles to their limits. The smaller wheels/tires are less expensive to replace, should you need to either during your ownership or at the end of your lease. Yes, I could afford bigger wheels and higher performance tires, but at least in the USA, where there are no unlimited speed roadways where higher than say an H-rated tire might be required (well, actually even lower), why pay for it?
If you really worry about what other people think, hey, fine by me. I'll spend my money on other things, like some fine wine, art, etc...I've owned an old Citroen and Volvo...neither particularly stylish vehicles, but they were functional for me and met my needs. |
Tags |
wheels |
