10-15-2019, 03:29 PM | #1 |
Rep 14
F31 weird dome light problem - help!
I've got a strange electronics problem: the interior dome light comes on when I open the door of the car, but not when using the switch on the light itself.
Because the light works it is possible to rule out bad bulb. I suspect the previous owner did some tampering with the electronics/coding. Anyone knows how to fix it? I want to be able to use the switch to turn on the dome light! Any help would be appreciated. |
10-20-2019, 01:06 PM | #2 |
NewFinishColumbia/detailer
604
Rep 2,096
This selection should be an option under the main menu/settings/lighting in the iDrive. Also you can change the interior lighting to orange (classic) and dim it if you want under the same menu. If it's not there in the iDrive then yes, someone has coded it to do so. I'm pretty sure it is though.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
11-04-2019, 10:48 AM | #3 |
Great Teacher
1100
Rep 1,308
Drives: 06 e91 325ix
I would look at the switch itself.
Do other button lights work for the doors as opposed to the main cabin light? Or do all 3 buttons not work. |
11-04-2019, 12:01 PM | #4 | |
55
Rep 297
I believe you need the extended light package in the UK for that. |
SteveInfante604.00 |
