EGR Delete question
10-14-2019, 09:32 AM | #1 |
Rep 20
EGR Delete question
I have done extensive searches on this topic but have not been able to find clear answer my question regarding EGR delete:
If I remove EGR and EGR cooler by adding race pipe, blocking off EGR exhaust at manifold, remove cooler and plug coolant lines must I get ECU tune to prevent going into limp mode? I understand without ECU tune I will throw codes and get check engine light. I want to understand if I can do EGR delete first and then re-tune at a later date. Can this be done? Do specific sensors need to remain connected? Thanks. |
10-14-2019, 09:47 AM | #2 |
1565
Rep 1,422
If you completely remove the EGR valve from the car, you will get limp mode until you get a tune. I believe if you leave it electrically connected but zip-tied out of the way (so you can install the race pipe), you will get codes but the car will work normally.
10-14-2019, 11:17 AM | #3 |
Rep 20
OK thanks - I guess that is an option, but would be a bit clunky.
Maybe this is a silly question but can one block the EGR exhaust, remove EGR cooler (plug EGR cooler lines) and just leave the stock EGR valve in-place and plugged in? Would there be any issues with that setup? The reason I am asking is I want to remove the EGR cooler due to 4873 code (and leak). |
10-14-2019, 11:23 AM | #4 |
Rep 20
Additional follow up to post #3
Understand that set up get codes thrown and SES light. I eventually plan on getting tune to remove the EGR codes but wanted to phase in the changes to spread the cost |
10-14-2019, 12:28 PM | #5 |
1565
Rep 1,422
I think you could remove the cooler, do the block-off and paperclip mod the EGR valve so it won't open. Prior to getting my tune and race pipe, I did the paperclip mod, but did not remove the EGR cooler. But I don't see why it wouldn't work.
Others with more experience/knowledge can hopefully step in and clarify. |
10-14-2019, 03:32 PM | #6 | |
357
Rep 1,723
'09 335D
Tags |
egr cooler removal, egr delete |
