10-04-2019, 10:50 AM | #1 |
BMW forever!
1392
Rep 2,420
The alignment keeps messing up. I just drove over a rough surface at 35 mph and it was not bad. Nothing compared to hitting a pothole. Now my car wheels are whacked up and probably need to re-align. It is not handling turns the same way it did prior to driving on the rough road. All my tire pressures are set perfectly. All my suspension components checked out fine at the dealer and all they said that it needs an alignment.
Is this a thing with modern BMWs? I only had to align my E90 once the entire 5 years that I owned and it was a much harder ride. That car drove straight and handled extremely well on any type of surfaces except potholes. But the point is that it didn't needed to be realigned that often. Anyone else have a similar experience with F30 alignment?
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i |
10-04-2019, 11:05 AM | #2 | |
119
Rep 191
I've had my F32 for north of 4 years. Couple of years into ownership I lowered it 1.75" front and 1.3" rear. No change in the frequency of when an alignment is needed. |
10-04-2019, 11:06 AM | #3 |
556
Rep 906
Get an alignment check at a reputable tire/wheel shop. If the check shows out of spec, then have the shop do an actual alignment.
I would take the dealer's recommendation with a grain of salt and get a second opinion.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
10-04-2019, 11:42 AM | #4 |
2001
Rep 2,499
You shouldn't require an alignment every 6 months. I haven't experienced any issues with my car's alignment going out of whack. Even after installing M Perf suspension which is considerably stiffer.
How many times have you had to have it aligned? It sounds like something is just coming loose for some reason. Next time you get an alignment, see what is out of whack. If it's just one or two things in the same corner, mark those with a marker like factories do to confirm bolts were torqued. Then you can quickly check to see if those go out of alignment again after 6 months. |
eluded3059.50 |
10-04-2019, 01:59 PM | #5 |
2984
Rep 6,036
My dealer always wants me to do alignment as it is a cash cow for them. Probably not necessary, sometimes they provide a printout showing they actually did something.
BeerHerder250.50 |
10-04-2019, 02:13 PM | #6 |
119
Rep 191
What's interesting is how they determine an alignment is needed without having placed the vehicle on an alignment machine. I don't suppose is being done each time they car goes in for service. But I so suppose obvious uneven or premature tire wear would be an indicator. But that would mean it would be obvious to the owner/driver as well.
10-04-2019, 02:17 PM | #7 |
Yoda of mods
1676
Rep 3,006
Drives: X5 RWD
Too often. They are just wanting your $$.
Current: 2020 Explorer ST (Agate Black Metallic), F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
10-09-2019, 11:51 AM | #10 |
BMW forever!
1392
Rep 2,420
Thanks, please see attached. I did this in May 2019. Can I modify any of the parameters to make this alignment even more aggressive? As in, to further improve the on-center feel, accuracy and tightness.
2020 BMW X5
10-09-2019, 03:50 PM | #12 |
BMW forever!
1392
Rep 2,420
Sorry, didn't upload for some reason. Can you see it now?
2020 BMW X5
10-09-2019, 04:52 PM | #13 |
251
Rep 426
My dealer wanted like $290 or something silly for a one time alignment. Got a 5 year package from NTB for $300. Unlimited alignment and transferable to a new car one time if needed.
I am currently having an issue with a slight pull to the right that I need them to fix...
Glacier Silver Metallic 335i X-Drive - Can't leave well enough alone... Fabspeed DP, Wagner Evo Comp II IC, ER CP, BM3 Stage 2 93 OTS, Bimmertech Amp (more to come... always more) Graphite Metallic X3 (nothing yet, but... you know) |
10-09-2019, 06:35 PM | #14 | |
BMW forever!
1392
Rep 2,420
2020 BMW X5
10-09-2019, 06:52 PM | #15 |
12
Rep 11
Are your wheels significantly lower profile than your E90? If you drive on many bad roads, little sidewall can contribute to this. Here in the Midwest the roads have all gone to hell and I find myself paying for a lot of alignments (and wheels) each year.
10-09-2019, 09:00 PM | #16 |
516
Rep 1,452
BeerHerder250.50 |
10-09-2019, 09:41 PM | #17 |
BMW forever!
1392
Rep 2,420
Yeah I have M performance suspension with 19 inch wheels, car is even lower than the stock sports suspension. But still, anyone I hit a rough patch of road, feels like car become a little less accurate in handling.
2020 BMW X5
10-10-2019, 01:18 AM | #18 | |
2JZ-GTE
3060
Rep 4,010
10-10-2019, 06:13 AM | #19 |
BMW CCA 69606
86
Rep 227
10-10-2019, 06:17 AM | #20 | |
BMW CCA 69606
86
Rep 227
What tires and air pressures are you running? Do you have the 2VL, variable sport steering option? |
