09-28-2019, 10:31 AM | #1 |
397
Rep 855
Wireless charging tray - not working?
I don't use it much. But I forgot to charge my phone last night so I put it in the tray for a 2 hour and 30 minute drive. I've had my suspicions in the past that it doesn't work well so I double and triple checked that it was actually charging.
2 hours and 30 minutes - 30% to 43% and the phone was about 1000 degrees. Does it really suck that bad or is mine malfunctioning? Iphone XS Max |
09-28-2019, 01:08 PM | #3 |
94
Rep 419
Drives: 2019 F90 M5B, 2006 E60 550i
Ive had better results by hooking up a Lightning cable to the USB port in the center armrest. But, I still prefer using the tray because it’s quickly accessible vs having it in the armrest. I always keep a microfiber towel on the armrest to prevent my body oils etc from staining the leather and the towel just gets in the way when driving to gain access to the armrest contents.
09-29-2019, 03:12 AM | #4 |
239
Rep 473
Mine charges pretty quick and doesn't heat up. Maybe you have a thick case on the phone or something? Not sure if/how that affects charging, my phone doesn't have a case.
Snapper Rocks Blue on Tartufo leather | All options except Homelink and tow hitch
Ryno 27251.50 |
09-29-2019, 08:24 PM | #5 |
62
Rep 774
Drives: E90 335i & E60 550i
Mine heats up pretty badly too, to the point that my phone starts crawling and barely works. Same results with or without case. I have an iPhone 10 XS. Really a annoyed by it. Had the same issue with an X4 loaner I drove for a day though I didn't try it without the case.
Pure S2 Turbos | Vargas Outlets | RB Inlets | OEM SS Kit & Performance Steering Wheel| LCI Rear Conversion | Euro Xenons | RD Sport Quad Exhaust | Spearco Intercooler | Cobb V3 | MORR VS7 | KW V3 | H&R Sways | Mtech Bodykit | Vorsteiner CF Hood, CSL Trunk & Front Lip | Quaife LSD | Rotora BBK | GruppeM Intake | Forge UK DV | AR Design Catted DP's
09-30-2019, 10:08 AM | #6 |
19355
Rep 10,166
It charges too slow and I have the new Note 10 Plus that can take a 45w charge- It probably charges at 5w LOL. I never use it and instead using 3.0 cigarette charging unit.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
10-01-2019, 03:54 PM | #7 |
1716
Rep 1,909
Drives: 2023 M5C
BMW should really just call it a battery "maintainer" not a charger. It allows you to use all of the phone's features while driving (Music, GPS, etc.) all while keeping your phone from draining...
IG @windtendo_m5
10-01-2019, 06:33 PM | #8 |
94
Rep 419
10-03-2019, 10:35 PM | #9 |
94
Rep 249
I have been playing around with the charging as some times my phone charges rather quickly while other times it doesn't go much up at all. Some things I have tried and observations:
What else have you seen? |
10-04-2019, 06:45 AM | #10 |
340
Rep 536
When I am using Waze my charger keeps the battery maintained / slightly charging. If just driving and listening to music (Waze app closed). I get a decent charge out of the phone while I the tray. Also have 10s max.
10-25-2019, 07:52 PM | #11 |
575
Rep 754
I have a Samsung Galaxy S10. Driving while using Spotify with the phone in the tray basically just keeps the battery the same. Same goes for my "official" Samsung wireless charger it home. It works but it's much slower than a USB or Wall charger
DME: 1848 DA 0-60 2.42 -- 1/8 Mile 6.38 -- 1/4 Mile 9.89 -- 60-130 5.91
Evolve: 1418 DA 0-60 2.48 -- 1/8 Mile 6.47 -- 1/4 Mile 10.05 -- 60-130 6.48 JB4: 1096 DA 0-60 2.54 -- 1/8 Mile 6.50 -- 1/4 Mile 10.05 -- 60-130 6.18 IG: @hockeytyme All runs on street with no prep on 21 inch wheels and PS4S tires |
12-02-2021, 04:50 PM | #12 |
Rep 7
Usually, I use waze and spotify. After 3 hrs the baterry is still at the same %, so it is just maintained. BUT the phone (iP 12 Pro) gets so overheated that it turns off!! So no waze and no music until it cools down. Pretty annoying.
12-02-2021, 11:57 PM | #13 |
239
Rep 407
I did a drive using Waze and listening to RadioParadise through the phone on CarPlay. I had the phone (iPhone 12 Pro Max) in the center console connected to a MagSafe charging disk plugged into the USB port in the center console.
The phone didn't even get warm. It did charge while playing. Less convenient, but lots more reliable. |
12-03-2021, 01:11 AM | #14 | |
48
Rep 69
Also, inductive car chargers take longer because their watt output is much lower than a household plug. The wireless charging is really just a place to keep your phone safe in the car and give it a few extra percent, as well as the place for the car to recognize the digital key. |
