The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Unusual glowplug fault
      09-19-2019, 11:23 AM   #1
ololiuqui
Drives: BMW e91 325d
Hey all,
So last winter my car started to having hard times starting in minus degrees. Carly said three of six plugs were off. I ordered a beru kit from ebay with 6 new plugs + module.
Changed everything and now carly told me all 6 plugs were non functional. I thought plugs were bad and got 6 new plugs and changed AGAIN () Problem did not go away and plugs still did not work.
I ordered a second module and switched, STILL SAME PROBLEM!?
So another winter is coming and non of the plugs is working, what do you think the problem is ? Plugswires? +wire ?
Carly is saying 1,2,3,4,5,6 glowplug nonfunctional.
Car is a 325d m57 from 2009 (LCI)
Module is BERU GSE 102.
      09-19-2019, 06:37 PM   #2
Mik325tds
Mik325tds's Avatar
806
Drives: 335d M-Sport
Maybe stating the obvious, but did you check the fuse?
      09-19-2019, 09:28 PM   #3
335stoner
BRR tuned
220
Drives: 335D black
Did you get your connectors seated all the way?
robnitro160.00
      09-21-2019, 11:15 AM   #4
PURE340i
104
Drives: 2018 BMW 340i & 2011 335d
That power wire going across the valve cover to the passenger side i believe.... check that because mine was left loose after carbon cleaning and it threw some weird glow plug and glow plug module faults.
      01-27-2020, 11:33 PM   #5
VladSonOfVlad
Drives: 2011 BMW 335d
Good place to check. 335stoner, I’m trying to get some contact info for BRR tunes. Having a hard time figuring out how to use this thread and PM system.
      01-28-2020, 12:35 AM   #6
335dlci
277
Drives: 335d
So you replaced Ebay junk with ebay junk?
      01-29-2020, 05:01 PM   #7
Tambohamilton
3058
Drives: E91 330d
A 2009 M57? You sure it's not an N57?
I think you may have the wrong control module.
