How can i make 2011 335d reliable
09-19-2019, 11:14 AM | #1 |
Rep 71
Hello,
I'm planning on picking up a 2011 335d to ship to europe. I would like to know what preventative maintenance i can do before i ship. I want to make sure all the big problems are taken care of. If anyone can help that would be great also i know nothing about these engines but have heard they are good. |
09-19-2019, 02:03 PM | #2 | |
765
Rep 3,556
Here is link to it in case you don't know where our stickys are. https://www.e90post.com/forums/showthread.php?t=1334283 |
09-19-2019, 05:55 PM | #3 | |
277
Rep 1,575
09-24-2019, 09:30 PM | #4 |
273
Rep 749
Forgetting about the awful emissions system, I’d start by replacing the red boost hose, the top turbo oil feed line, and the harmonic dampener. And maybe vacuum lines depending on age.
09-25-2019, 08:44 AM | #5 |
307
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
In spite of what you read on the forums and my personal experience...... I can say a lot of folks make it well over 100k without emissions issues. If your car doesn’t have a history of problems it’s probably going to be okay for a while.
09-26-2019, 09:43 AM | #7 | |
142
Rep 634
They did a ECU software update with the CBU cleaning and ever since then the car uses very little DEF, in the order of 1 quart per 1000 miles. |
09-26-2019, 01:53 PM | #9 |
Curmudgeon and Pedant
690
Rep 3,489
While I've had emissions problems (including NOx sensors and DEF tank replacement, etc.), the last couple problems have not been emissions related: glow plugs and controller, and throttle. They had the manifold off and the CBU was mild-to-moderate. 138K miles.
09-27-2019, 01:05 PM | #11 |
126
Rep 246
About 310000 miles on mine, 325D though. Engine stock with DPF/EGR.
I use Common Rail fuel additive every fillup and change oil 6500 miles (both Liqui Moly products). Most reliable engine i've ever owned... just drive and enjoy. |
09-29-2019, 09:17 PM | #12 |
273
Rep 749
My 335d has 80k miles. Quick break down of issues:
SCR cat failure 35k miles (warranty) NOX Sensor failure 40k (warranty) Glow Plug Mod Failure 55k (out of pocket) Active Tank Failure 60k miles (warranty) Red Boost Hose Failure 60k (out of pocket) Top turbo oil feed failure 60k (out of pocket) DEF Delivery pump failure 80k ($$$ out of pocket) Cracking Harmonic Damp 80k (out of pocket) Failed MAF sensor 80k (out of pocket) Preventative I did DPF cleaning at 55k, trans and diff fluid at 60k, thermostat at 75k. Overall the car has been decently reliable. One issue is finding a knowledgeable bmw diesel tech. |
09-29-2019, 11:41 PM | #13 |
Rep 31
All the maintence items
Water Pump All deletes + Tune CBU Fluidamper Balancer Trans Service Complete fluid flushes Fuel Filter Thermostat All new vacuum lines Diff drain and fill That should make for a pretty reliable D |
10-02-2019, 01:00 AM | #14 |
Rep 5
10-02-2019, 01:55 PM | #15 | |
107
Rep 202
The US market cars have a selective catalytic reduction system not present on the Euro market cars. Basically: a urea tank and injection system to aid in NOx reduction. Anyway, are you sure that you really have a Euro-spec model? Or was that just something the shifty used car salesman said in an effort to make you think you were buying something super-special? |
10-02-2019, 01:57 PM | #16 | |
690
Rep 3,489
Now, if you've bought an F3x, all bets are off (only 535d/540d, 740d have diesels, and they are N57 not M57.) |
10-02-2019, 03:36 PM | #17 | |
107
Rep 202
The US market cars have a selective catalytic reduction system not present on the Euro market cars. Basically: a urea tank and injection system to aid in NOx reduction. Play around with realoem.com and take a look at US and Euro market 335d's and the exhaust and fuel systems sections for each. Anyway, are you sure that you really have a Euro-spec model? Or was that just something the shifty used car salesman said in an effort to make you think you were buying something super-special? |
10-02-2019, 03:37 PM | #18 | |
690
Rep 3,489
10-02-2019, 05:18 PM | #19 | |
357
Rep 1,723
535d and the 540d use different engines. B57 in the 540d.
'09 335D
