Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Upgrading my fuel system, Limp mode. Help
      09-13-2019, 01:36 AM   #1
Dawe_a
Drives: e91 335D / E61 535D LCI
Hello guys
I have a high speed limp mode problem (the notorious 428b code at 2.51 bar high speeds) have tried 3 maps and changed everything from MAP sensor, vac lines, MAF, tested vacuumpump, tested wgs, all pressure converters new etc etc but can't stort it out, I think it is fuel related.
(running stage 2 , Dpf off, egr off ~370hk/700nm)
Im about to fit a R90 pump (R70 std) and new injectors , do i need a bigger "high pressure fuel sensor" on the fuelrail? if so, is the Pre-lci fuel pressor sensor bolt on and the one to go with?
And is there any upgrade bolt on MAP-sensor available to this engine? ( 535D 2009 LCI Euro), sry for posting in 3 serie forum but i didnt find any M57 section on 5 serie forum.
and last, is there any upgraded injectors available for this engine or how much power is the stock bosch piezo capable of?
My main problem is limp mode (code 00428b) at high speeds, around 200km/h otherwise the car is running perfectly.
      09-13-2019, 07:10 AM   #2
RL18
274
Drives: 2011 335d sport
Originally Posted by Dawe_a View Post
Hello guys
What's the description on the code?
Have you logged what your fuel rail pressure is doing when that happens? What gear are you in when it happens? Rpm?
You should really log parameters on what's happening when this occurs because we don't have much to go off of with just a code.
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R.
      09-13-2019, 08:49 AM   #3
robnitro
160
Drives: x5 35d e70 2011
You don't need a different rail pressure sensor since the pump is just there to help hold pressure at high fueling, not make more pressure.
      09-13-2019, 01:46 PM   #4
Nadir Point
Nadir Point's Avatar
103
Drives: Diesel
Originally Posted by RL18 View Post
You should really log parameters on what's happening...
I'd be interested to know variability and repeatability in connection with time deep in the skinny pedal at what boost level(s). Then, is it REALLY limping, or just illuminating a dash lamp, and what happens to that indicator 2 minutes later.
      09-14-2019, 03:46 PM   #5
Dawe_a
hello again! Havent logged anything but it says "00428b - Boost pressure control low pressure stage, deviation"
It goes into real limp-mode at around 200km/h , often when shifting from gear 4 to 5 in wot. No lights just complete loss of power/boost until i restart the car.
I have read out this information with the fault code in inpa,
fuel pressure: 1699 bar
boost pressure: 2.510
temps are OK. I think its maybe a faulty injector or so? many ppl seems to have this problem after DPF off. And there is really no real solution for it.
Ok thanks! Can i get a better bolt on map-sensor? This OEM one is 2.5bar or ?
      09-14-2019, 04:59 PM   #6
RL18
274
This is exactly why we need logs! Because we could see if it's something like the r70 pump on it's last leg not getting enough fuel to the rail. Or it could be something as simple as a bad fuel rail pressure sensor. Not really sure though
OP just curious have you ever used a piggyback tuner that tricks the fuel rail into requesting more fuel (like jbd)? I remember seeing somewhere on here that someone experienced the jbd ruining their fuel rail pressure sensor. Just a thought. A bad injector could be an issue but you should have injector codes. Have you talked to your tuner about this issue? Could be a tuning issue also. Boost looks good though my 335d requests about the same. Any weird noises when this happens?
      09-15-2019, 02:26 AM   #7
Dawe_a
Hello. I want to log but dont know any good program for that, I really want to get to the bottom with this problem, its really annoying.
I have an K+Dcan cable, android phone, computer and some basic computer skills. Do you guys any good and simple logging program?
I havnt use any piggyback, just real tunes. I have been testing 3 different maps from 2 tuners and limp mode is happening with all of the tunes. Those remappers are well known here in sweden and telling me they have remapped tons on stage 2 35D´s so i dont think there is a problem with the tunes. Maybe some tuners just disable the limp mode function?
Have google this problem in months and have been reading that if th boost pressure differ +/' 0.3 bar from set boost its trigger limp mode?
My actually boost pressure VS set boost pressure can differ up to 0.5 bar some times, maybe there is a stuck wastegate? I have been filming my wastegate when applying vacuum to it with an vacuum-gun and its moving a little bit, dont know if its enough. I will remove the DP to check the movement of the WG on big turbo.
i have new MAF-sensor, Map sensor, new VAC hoses, two new pressure konverters, new diesel filter, new air filter, removed swirl flaps. I have also tested vacuum when driving, with manual vacuum gauge and vacuum is perfect.
There is no noises when this happen its just stops pulling and loss all boost pressure. Its like its cutting of all power when its hitting 2.51 bar of boost to protect the engine.
I have some videos of the problem:
Here its hitting limp mode (2.57 bar boost):
Here its in limp mode (wot ant end of video) :
My english is not the best but i hope u understand me.
Best regards
David
      09-16-2019, 10:22 AM   #8
Dawe_a
I think i will start to change the R70 pump to a R90 one, my diesel pump is little bit wet on the back, like its leaking somewhere.
I got no codes on injectors. If its not an faulty diesel pump i anyway got the better R90 installed for future mods. I finded an refurbished R90 for 235 euros.
*Does anyone know if i need to upgrade my map-sensor at any point? And to what sensor ? Or is stock MAP sensor good for ~450hp?
* how far can I go with stock fuel pressure sensor (bar)? is there any upgrade? Seeing that some ppl is going for the 2700bar M50d one.
* does anyone know what the rail pressure should be at idle?
      09-22-2019, 06:31 AM   #9
Dawe_a
hello again, did check my wastegate today, is this normal? If i push it little bit more open (as in the end of video, it stays there but its only goes a little bit open by only vacuum).
i have adjust it a little bit now, dont think that solves the problem.
      09-23-2019, 04:50 AM   #10
Yozh
Yozh's Avatar
No_Country
870
Drives: 2011 335d M-Sport
Some have had issues with this code and it was tune related where map needed a rescale.
      09-24-2019, 12:03 AM   #11
Dawe_a
I think so too.. but the fact that i have tested 3 differents maps had me to think that the car is broke in some way... but it seeems to that its not..?
I have stable fuel pressure all the time until i hit limp-mode , its seems that the problem is overboost ? Cant the remapper remove the overboost-limp mode?
I have like 0.2-0.45bar "overboost" (set vs actual boost pressure differens) even when im cruise at 60-70mph on the highway.. The wastegate isnt stuck.
      09-24-2019, 12:08 PM   #12
Yozh
Yozh's Avatar
No_Country
870
Have you done any data logging to see your parameter behaviour when the limp mode happens. A simple rpm, pedal, speed, emp, boost desired, boost actual would do.
      09-25-2019, 02:19 PM   #13
jordyhulst
Drives: BMW E92 335i
i have experience with this code with a E60 535D LCI Stage 2( Downpipe+Remap).
the solution was to make the port of the wastegate bigger from 10mm to 14/15mm.
this will solve the overboosting problems.
its a common problem with a M57TU2TOP when you remove the DPF.
      12-17-2020, 08:19 PM   #14
VladDiesel
Drives: 2011 335d (SOLD)
Any updates on this?
      12-19-2020, 12:42 AM   #15
mFifty7
Dirt Nasty
Drives: ‘11 M57 335D
Yes, please! I have the same issue. I thought boring the wastegate wasn’t needed?
      12-31-2020, 11:15 AM   #16
Owen81
83
Drives: 335d, 17/22 TDI
All of the tunes in North America were updated to mitigate the need for wastegate boring as far as I've heard.
      12-18-2022, 10:12 AM   #17
Dawe_a
new tune sorted the problem..
      03-09-2023, 12:24 PM   #18
coco35d
coco35d's Avatar
Drives: bmw e92 335d
Got same got 428B
Currently running 340hp mapped and dpf removed.
So new map will fix the limp mode?
      03-11-2023, 12:02 PM   #19
Nadir Point
103
Drives: Diesel
https://www.e90post.com/forums/showt...1028793&page=2
      03-12-2023, 10:15 PM   #20
RL18
274
Now that I know more about this… if you’re running a r70 or r90 fuel pump. There is NO need for injectors and it actually is mostly likely the cause for the codes. Neither pump’s can supply enough fuel to support bigger injectors. Period. Our stock injectors are good for somewhere around 500whp which can be achieved with dual fuel pumps, valve springs and hybrid lp turbo. You can squeeze more out of them too if you go with the triple turbo setup…
If you want to run bigger injectors then you need to run dual fuel pumps, valve springs, and hybrids to get anything out of 100% injectors. The fastest x5d currently (BRR tuned) with that setup did a 11.61 1/4 mile @ 116.72 mph, which is more than 550whp.
Id have to look up the 335ds with the same setup but I’m pretty sure with stock injectors they’re getting low 11s in the 1/4 mile.
      03-13-2023, 01:14 PM   #21
Nadir Point
103
Drives: Diesel
TRANSLATION: Now that somebody did the search for me...
      03-13-2023, 01:18 PM   #22
RL18
274
Who searched it for me? Their fix was a retune, which probably adjusted fuel being requested. But the issue is because the r70 and r90 can’t support larger injectors.
