09-04-2019, 07:26 PM | #1 |
641
Rep 1,383
Which pins for f32 lci tail lights
So I fitted my own LCI's a little while ago with splice crimps, however this weekend I'm installing another set for someone (I've sold my old ones and the guy wants them installing).
Obviously he's not keen on the splice idea, so I need to figure out the pinning situation. From what I've read online I should be doing the following: Inner left light to REM 174*12b pin17 Inner right light to REM 174*14b pin12 But then I've read pins 13 and 5.. Can anyone clarify which it really is? There's not many clear pictures online so I have zero idea. Thanks.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
09-05-2019, 03:43 AM | #2 | |
588
Rep 2,302
For the inner right and left flash light are the pins REM A174*13B Pin 5 (left) and A174*13B Pin 13 (right). But these new pins will only work if the car is coded and the car knows of these codings. I mean that if the car does not know this coding values (software too old?) then it does not work either. In that case you have to connect the wires at 174*12b pin17 and put 174*14b on pin12. edit: Or you can update the software of the REM and the coding should work Last edited by atzebmw; 09-05-2019 at 04:47 AM.. |
