Factory Boost Sensor
09-04-2019, 06:48 PM | #5 |
Rep 31
Actually the car makes 60 psi on current tune.
I purchased the white m sport from Jerry Adkins - the one originally from DieselOpa with the custom Comp Turbo setup on it Has valve springs, and ARP head studs. Holds the boost fine - was at 68 actually. Still working on the tune with Malone currently. |
09-04-2019, 07:26 PM | #6 |
160
Rep 803
If you are fooling the tune as your logs show, maybe it's better to just run a mechanical boost valve on the tdi we used a Dawes device, boost valve with the breather sealed shut to work on vac system... It opens and kills the vac, which opens the vac actuated vanes/wg up.
But then with 2 stages it would be hard to figure what to do with the small turbo. I suppose using 2 boost valves, one for each turbo would work. |
09-04-2019, 07:36 PM | #7 |
Rep 31
The first goal is just to get all the logging in one place. Protool works fantastic, the MAF has been deleted as it’s out of range. We have a 5 bar map and manifold EGT logging from the edge 2
09-05-2019, 07:06 PM | #9 | |
23
Rep 133
