08-17-2019, 10:58 AM | #1 |
211
Rep 274
Just got these in and plan to put them on tomorrow. 15mm for the fronts and 12.5mm for the rears.
I took the opportunity to grab some new tools for the garage. -3 Ton Floor Jack -Breaker bar -Torque wrench -Protective socket set [img] View post on imgur.com [/img]Parts for install: ECSTuning ECS 15mm Wheel Spacer Kit & ECS Conical Seat Bolt Kit https://www.ecstuning.com/b-ecs-part...002411ecskt17/ ECS 12.5mm Wheel Spacer & ECS Conical Seat Bolt Kit https://www.ecstuning.com/b-ecs-part...002411ecskt18/ Anti-Seize Lubricant - 8oz https://www.ecstuning.com/b-permatex...8oz/80078~pmx/ [img] View post on imgur.com [/img]Step 1 - Break the bolts and jack the car up and completely remove the wheel. [img] View post on imgur.com [/img]Step 2 - Clean hub surface and apply anti-seize grease to the contact points where the spacer will meet the hub. Do not apply anti-seize to lug bolt threads or lug bolts. [img] View post on imgur.com [/img][img] View post on imgur.com [/img]Step 3 - Grab your spacer and align to the hub making sure to line up lug bolt threads and re mount your wheel. [img] View post on imgur.com [/img][img] View post on imgur.com [/img][img] View post on imgur.com [/img]Step 4 - Be sure to apply the recommended torque settings for your spacers. See screen shot from linked pdf - http://bd8ba3c866c8cbc330ab-7b26c6f3...eelSpacers.pdf [img] View post on imgur.com [/img][img] View post on imgur.com [/img]Step 5 - Check out your before and afters. Much wider stance and the 12.5mm and 15mm and getting these wheels flush with the fenders now. I really like the look from the front with the wider stance. BEFORE [img] View post on imgur.com [/img]AFTER [img] View post on imgur.com [/img][img] View post on imgur.com [/img][img] View post on imgur.com [/img][img] View post on imgur.com [/img][img] View post on imgur.com [/img]Thanks hope this was helpful!! -vicfalc09 Last edited by vicfalc09; 08-18-2019 at 11:23 AM.. |
08-22-2019, 07:52 AM | #6 |
211
Rep 274
11-13-2019, 06:10 PM | #11 |
5219
Rep 3,932
