08-16-2019, 03:56 PM | #1 |
Supreme Allied Commander
3814
Rep 54,307
Drives: F80 M3
KW V3 BMW G29 Z4 & Toyota A90 Supra
If you have already made the first performance modifications to your sporty street vehicle, KW coilovers Variant 3 can further enhance your performance with our targeted damper settings. The patented KW-valve technology for the separate adjustment of rebound and compression damping, allows you to individually adapt the vehicle-specific basic setup. With independently adjustable compression and rebound damping, the Variant 3 damper setup can be tuned to your own driving preferences or vehicle modifications such as weight, tire characteristics or additional chassis bracing. True performance optimization is only possible with this unique, patented system. For example, the compression damping force can be increased to optimize grip from the tires, or improve cornering behavior and reduce squat without influencing the rebound damping characteristics that are optimally tuned to the spring rate. Application: 2020 Toyota A90 GR Supra BMW G29 Z4 M40i
Part Number: 352200CG KW Coilover Kit V3 2019+ BMW Z4 sDrive M40I (G29) / A90 Toyota Supra More details to come later... |
