Any way to keep my engine temps down?
08-11-2019, 09:33 AM | #1 |
166
Rep 428
Drives: 2008 BMW 335i Coupe
I live in Texas where it’s usually 95+ degrees even around 11 pm at night. My hood is usually hot enough to fry a couple eggs on it after just 5 minutes of light driving. Is there any other way to keep engine bay cool? I have a ARM 5 in inter cooler, 1 year brand new radiator, but I do have BMS DCI and removed the stock box and filter. Thanks
08-11-2019, 12:16 PM | #3 |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
Heat wrap, aftermarket oil cooler, bigger intercooler. Check out certain ducting mods to get better airflow like the aFe air scoops behind the kidneys, or something along the line of how Dinan made their ram-air intake by ducting extra air from the front left bumper grill, near the foglight.
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
08-11-2019, 07:11 PM | #4 | |
37
Rep 233
08-11-2019, 09:36 PM | #5 | |
1044
Rep 1,667
tisdrew97.50 |
08-11-2019, 10:23 PM | #6 |
Rep 5
I would just watch your engine temps. If that is good then you should be fine.
thormessiah165.50 |
08-12-2019, 08:19 AM | #8 |
98
Rep 300
BMS has a cheap oil cooler thermostat in addition to the things everyone has mentioned. I would look into water-meth injection if you're open to that.
"Wheels and exhaust aren't a build"
thormessiah165.50 |
08-12-2019, 10:58 AM | #9 |
166
Rep 428
Thanks all! I will probably save up for the CSF radiator which is a big upgrade over the stock one
08-12-2019, 12:42 PM | #10 | |
2440
Rep 4,330
the factory setup is perfectly capable of overcooling the engine. the thermostat is what keeps the heat in the engine. also, a better radiator isn't going to decrease underhood temps. all that heat is still going to flow from the back of the radiator into the engine bay. if you want cooler engine bay temps you need to vent the engine bay. |
08-12-2019, 01:18 PM | #11 | |
1007
Rep 2,243
Drives: 2007 328i / 2014 M235i
Maximum efficiency is gained at higher temps. I would make sure your oil is full and you can remove the vanity cover. When the car is stone cold, use a garden hose to spray the radiator and evap fins. From what I remember, driving in DS mode keeps the water temperature lower by running the electric water pump faster but you will lose efficiency. These cars have very intelligent cooling systems. |
08-12-2019, 08:37 PM | #13 | |
166
Rep 428
08-12-2019, 08:57 PM | #14 |
659
Rep 1,525
Ding ding. I have the AD Engineering one, thought to be the happy medium between summer cooling and winter heating. Friday night going out for dinner it was 107 degrees out. While cruising at 85 mph the temp gauge on my ride was comfortably pegged at 210.
08-13-2019, 12:34 PM | #15 |
15
Rep 154
That might be the stupidest proposition you will hear but maybe putting a higher viscosity oil (5w40 instead of 5w30 if that's what you're using) will help with oil temperature. I'm not sure how accurate and effective this is so roasting is welcomed
thormessiah165.50 |
08-13-2019, 02:45 PM | #16 |
166
Rep 428
Actually I also heard this from 2 guys who worked on my n54 about a year ago. They were using Rotella 5w40 because they said it ran a little cooler. I had my oil changed at a local store so they used 5w30 but I'll be using 40 from now on.
08-13-2019, 03:37 PM | #17 |
88
Rep 863
Would using 5w40 damage the engine in anyway? Instead of stock 5w30? I live Denver, so temperature can be from 0 to 100 f
08-13-2019, 03:52 PM | #18 |
15
Rep 154
No, definitely no harm. In the contrary actually, 5w40 is more viscous, so it would provide better lubricantjon in hotter climates. However, I am not sure about this statement either, but in freezing temps, it doesn't provide the best lubrication in tight areas on and during cold start/idle. BMW does recommend both oils in the manual, so just make sure it's a BMW long life 01 approved oil. Castrol edge, pentosin or liquy moly are all good. I get my liquy moly from FCP euro as a kit with the filter, and with the lifetime warranty, I buy a new kit, send the old kit with the old oil for 18$ back, and get the new kit price refunded to me, so it's 18$ oil changes haha
08-13-2019, 04:46 PM | #19 |
55
Rep 147
08-14-2019, 11:48 AM | #20 |
2440
Rep 4,330
if your goal is a cooler engine bay, yes.
I'm still not sure what your goal is here. you talk about engine temps but then you talk about your hood being hot. Your engine is designed to run hot, that's just how it is these days. IIRC the upper map for the thermostat is like 215. twenty years ago that would have been the red mark on the gauge. if your car doesn't overheat, it's fine and working just as designed. |
