08-06-2019, 10:58 AM | #1 |
Everyday I'm shuffling
449
Rep 1,098
Is there an easy DIY fix for light curb rash?
I've got some on all four wheels. I don't know how it happened. All I know is that I'll up size the tires when I change them. The ones that BMW installed are narrower than the wheels.
08-06-2019, 11:15 AM | #2 |
Moderator
7517
Rep 19,368
Your question had me curious, so I decided to Google it:
https://www.google.com/search?q=fix+curb+rash I'm not sure if any of those links or videos are useful, but it's probably worth checking out. |
08-06-2019, 12:40 PM | #3 |
Car Geek
3700
Rep 3,618
If you have stock wheel and tyre sizes, BMW installs the maximum tyre width certified by the tyre manufacturers, i.e. 225/40-18 tyres on 7.5" wide wheels and 245/35-18 tyres on 8" wide wheels.
08-06-2019, 01:22 PM | #4 | |
449
Rep 1,098
Could be some marketing BS to justify their cost cutting choice. Tires are definitely cheaper as you go down in size. In every BMW that I owned (4 so far) I've up-sized (for example, go from 245/35-18 to 255/35-18) and everything worked just fine. I'd say worked better. For example the speedometer - it's a known fact that every manufacturer sets the speedometer to read a bit faster than actual speed. That's to protect themselves from liability. If you upsize your tires one size, the speedometer gets much closer to actual speed. |
08-06-2019, 01:23 PM | #5 | |
449
Rep 1,098
08-06-2019, 02:14 PM | #6 |
14
Rep 46
My local BMW has a mobile wheel repair guy come by weekly, I have used him in the past and you could never tell the wheel was rashed before. i believe it typically costs around $125~$150 per wheel for the repair.
08-06-2019, 03:32 PM | #7 | |
Car Geek
3700
Rep 3,618
The manufacturer specifies a wheel rim size that a given tyre will fit on i.e. they are "certifying" the fitment. These are pretty standard now across most radial tyre sizes. In case of the 225/40-18 size, Michelin, Bridgestone and Continental all specify 7.5 to 9.0" wheel width with the optimum being 8", with the 245/35-18 size they all specify 8.0 to 9.5" with 8.5" the optimum, 255/35-18 requires a minimum 8.5" wheel width. Going down a wheel size can allow a wider tyre to be fitted to a narrower wheel, for example 235/45-17 will fit on a 7.5" to 9.0" wheel. The easiest way to find this info is to go to sites such as tirerack.com and looking up the tyre spec info. Some tyre places will not fit tyres outside the manufacturer specified ranges, others will warn you that they are not "certified" for the wheel width you have. A small variation beyond the range will typically just lose performance and potentially lead to uneven tyre wear due to the tread not laying flat on the road. Too much outside the range can cause the bead to come off the rim. |
08-06-2019, 03:41 PM | #8 |
3079
Rep 5,578
Climate Changer110.00 EVEda235i90.50 |
08-06-2019, 07:00 PM | #9 |
Moderator
7517
Rep 19,368
That’s fair. I just thought it was interesting that there are how-to videos out there that explain how to fix this type of damage (it honestly had never occurred to me before), so I figured it was worth bringing them to your attention.
08-07-2019, 09:03 AM | #10 |
110
Rep 278
Drives: 2018 230i xdrive convertible
08-07-2019, 03:51 PM | #11 | |
449
Rep 1,098
The rashes in my wheels are much less than hers. So I was hoping for a fix that doesn't require taking the tires off. But one difficulty is... the finish where it's damaged is almost like a polished finish. Sanding and painting won't match nor look good. I don't want to paint the entire wheel. Last edited by MPBK; 08-07-2019 at 04:05 PM.. |
08-07-2019, 07:06 PM | #12 | |
3079
Rep 5,578
I know that I don’t like any kind of two-part plastic mixture that gets shaped and sanded once hardened. More severe damage can use high pressure rollers or even welding to make a repair. But the damage in the picture above is so minor, I would not stress over it and would let it be. Last edited by overcoil; 08-14-2019 at 02:30 AM.. |
08-13-2019, 10:10 PM | #13 | ||
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
Take your time with sanding. The less material you remove the better. Its easier to control the amount of material removed with a higher grit. But it does take longer. Patience is key. After sanding use some quality aluminum polish. If it needs more shine after that u may need a light clearcoat
Quiet M235i
08-17-2019, 07:08 PM | #14 |
Rep 7
I don't think you can restore your wheel with DIY. I would highly recommend calling your local wheel repair shop
Baltimore's Best
https://www.arsdentrepair.com |
08-18-2019, 09:44 AM | #15 | |
114
Rep 448
