08-03-2019, 01:17 PM | #1 |
Supreme Allied Commander
3841
Rep 54,352
Drives: F80 M3
BMS Elite F90 M5 Intake, Performance Filters and Mounting Hardware
BMS Elite F90 M5 Intake, Performance Filters and Mounting Hardwa Click To Enlarge Manufacturer: BMS Condition: New Share Featuring high quality S&B inverted cone filters the BMS Elite F90 M5 Performance Intake offers the highest possible flow in an attractive and easy to install/remove package. Not to mention the intoxicating sound. The BMS Elite M5 Performance Intake retains everything that is good about the OEM intake system including the cold air ducting and light weight heat shielding airbox bottom; but, completely replaces the restrictive top end of the OEM intake with new high flow ducting and 2 performance filters to match. Includes all required hardware. Does NOT require any cutting or drilling. While the factory intake is very high flowing the BMS Elite intake provides power gains of up to 10whp range at 25psi+ boost levels. Turbo spool up speed is also improved. Made in USA. BMS Elite intake for F90 BMW M5 APPLICATIONS BMW M5 • 2018 F90 M5 Order here: https://www.hpashop.com/BMS-Elite-F9...?categoryId=-1 |
