Non Starting E90 320d
07-26-2019, 12:13 PM | #1 |
Rep 3
[FONT="Times New Roman"]
Can anyone help me. I had my car diagnosed and fault code came up "No fuel pressure in common rail." Checked both electric fuel pumps both working okay. Decided to change high pressure fuel pump. Before doing so I checked that the fuel pipe going to the fuel rail was not blocked. All okay still no fuel getting to the fuel rail after changing high pressure pump. Tried replacing injectors again still will not fire up. Tried disconnecting wiring to HP pump again still no fuel getting to the fuel rail. Does anyone have any idea what on earth has gone wrong with my car. I am into it so deep now. Please please if you have any ideas they would be most welcome, I am at my whits end. |
07-27-2019, 03:30 AM | #2 | |
99
Rep 237
Also what year is your 320d? There are a couple of different engines that come in them depending on what year the car is. Does your car have an electric pump in the tank and another underneath the car around the passenger seat area? If you have a scan tool you should be able to check the pre supply fuel pressure in the DDE. Last edited by N52bigblock; 07-27-2019 at 04:15 AM.. |
07-27-2019, 06:37 AM | #3 |
Rep 3
Thanks for the feedback. Had the car diagnosed in a garage. They told me that the only fault that they could find was no fuel pressure in the common rail. So I can only take it that if the fuel pressure was low prior to the high pressure pump that it would also have flagged up a fault code. I just started with the electric pumps thinking that they may have been at fault. Trying to fix it myself not wanting to pay BMW their exorbitant rates. But the amount of money I have now put into it I might have been better off just letting them do it. Oh for the days when a competent D.I.Y.er could fix things.
07-27-2019, 01:37 PM | #4 | |
99
Rep 237
