07-26-2019, 11:21 AM | #1 |
5894
Rep 10,262
Navigation map freezes / returns to current position moments later
Vehicle: 2017 BMW 440i Gran Coupe.
Symptoms (intermittent, no consistent pattern): - Navigation is active / directing to an address - Map is moving and then stops - Map starts moving again (snaps to the current position) a few seconds later During the first visit to the dealer, two items were identified: - HU-H fault code - SI B65 09 15 The vehicle was reprogrammed but the problem persists. During the second visit to the dealer, nothing out of the norm was reported. No codes. I plan to scan for codes myself when the vehicle is ready. I called BMW NA and they suggested field representative to visit the dealer. I sense this will be a long journey. After researching similar symptoms, failing hard drive inside the NBT head unit seems to be the culprit. Did anyone encounter a similar problem? |
08-03-2019, 06:36 PM | #2 |
5894
Rep 10,262
Sharing an update.
The car has been at the dealer for a week. No progress in finding the root cause. The only logical conclusion is the likelihood of hard drive inside head unit intermittently failing - hence maps freezing. |
08-09-2019, 09:57 PM | #3 |
5894
Rep 10,262
Sharing an update. The dealer could not find any problems. No faults. Very unusual. This is 2nd time the dealer is trying to diagnose this issue.
