429A low pressure underboost; many new parts I'm at a loss. HELP!
07-23-2019, 09:29 AM | #1 |
32
Rep 160
Posting here for additional viability
This is cross posted on NA BMW Diesel Owners 429A low pressure underboost; many new parts I'm at a loss. HELP! I've been chasing this issue on my 2013 35d for a while now, and cannot seem to figure it out. Currently have 107k miles, new water pump, thermostat, glow plugs, glow plug controller, vacuum res, vacuum controller, pressure converters and vacuum lines, boost hose seals, cleaned MAF.
Any help\guidance is appreciated.
2008 E90 335xi - DPs, 5" IC, MHD Stg2+, xHP Stg3, xDelete | 2013 X5 35d - DUDMD Stg1, EGR Delete
07-23-2019, 01:06 PM | #3 |
32
Rep 160
I haven't been able to find any exhaust, turbo or boost leaks.
07-23-2019, 03:26 PM | #6 |
75
Rep 392
what egr delete kit did you use? it could be leaking at the exhaust manifold.
Your dpf could be clogged as well. Also could be an issue with vacuum lines/reservoir. Reservoir is pretty easy to test.
535D Xdrive DUDMD Stage 1
x5d e70 DUDMD stage 2 tune |
07-23-2019, 04:58 PM | #7 |
32
Rep 160
07-23-2019, 05:00 PM | #8 | |
32
Rep 160
Vacuum lines, pressure converters and res have all been replaced. Considering the dpf, not sure how to confirm this yet? Last edited by madbim; 07-23-2019 at 05:16 PM.. |
07-23-2019, 05:01 PM | #9 |
277
Rep 1,576
07-23-2019, 05:48 PM | #10 |
32
Rep 160
Ahh good call; I'll look to see if I can find any oil seepage around the valve cover.
07-23-2019, 05:50 PM | #11 |
277
Rep 1,576
07-24-2019, 02:34 PM | #12 |
217
Rep 1,909
I don’t know the m57 too well but on the n54 I plugged my air compressor into the diverted valve and compressed the whole system, then listen for hissing sounds ...
Turned out it was the diverted valve itself leaking Haha, now I have forge DVs that can handle high boost, anyway back to m57 I’m not sure if they have those or not... also Intercooler connection was leaking boost at some point too I had to reseat it Last edited by 007_e350; 07-24-2019 at 02:40 PM.. |
07-25-2019, 10:50 PM | #13 |
32
Rep 160
Map sensor was replaced tonight, as anticipated no change still the same error.
07-28-2019, 04:27 PM | #15 |
32
Rep 160
07-28-2019, 11:16 PM | #16 |
870
Rep 2,615
Madbim we had a good discussion over on FB. I think Dima has a great suggestion to check that your SCR is not clogged. Remove the metering valve and see what happens to the exhaust pressure. Also, please confirm that regenerations happen.
08-04-2019, 06:27 PM | #17 | |
32
Rep 160
08-24-2020, 11:44 PM | #21 |
Rep 26
Thanks for the update. I received the same error in a pull from a standstill in 3rd. Twice. Someone told me it could be a vacuum leak. Since I want to keep my alphabet and run meth, I am pulling my intake and running new lines next week.
Glad you figured yours out! |
