Car shaking. Any ideas?
07-22-2019, 12:47 AM | #1 |
57
Rep 264
Hey guys, my girl has a 2013 n55 335i. Her car would shake while driving and stopping because her rims were shot. She just put a new set on. The car no longer shakes when driving, but it still shakes when braking. Any suggestions on the cause? I am thinking maybe her rotors are warped, but recently, after changing from her winter set to a different set, she would occasionally experience the steering wheel randomly shaking uncontrollably. The car would also lean to one side, almost as if you would experience when you have a flat. It happens at the most random times and would go away after a minute or if she pressed on the breaks it would stop as well. I am not sure if this and the car shaking when braking is from the same cause or are unrelated. She also loves hitting potholes but just had an alignment recently. Thanks in advance!
07-22-2019, 01:27 PM | #4 | |
2697
Rep 4,031
https://www.newtis.info/tisv2/a/en/e...wheels/4E2zA7N You need to learn how to REMOVE & INSTALL her wheels -- she'll thank you for it. NOTE the "Special Tool 81 25 2 344 011" (the "BLUE Thingy") used to clean the hub "centering" shoulder. Actually ANY wire brush will do if you understand what you are doing. The idea is remove "crud" (German technical term ;-) from the Disc Shoulder where the wheel mounts which will prevent the wheel from "centering" or fitting on the "hub-centric" disc properly. You also need to clean the center of each wheel so that the wheel fits properly (does NOT cock or install "off-square." Odds are one or more of the wheels is difficult to remove, or else is sloppy to the point of wobbling when installed. Also, check "Brake Disc Retaining Bolt" to make sure it is snug. If you have a Magnetic Base Dial Indicator, measure "Runout" or movement inboard/outboard of the disc in the wear area as you turn the wheel. There may be "crud" between the inboard face of the disc and the hub which causes the Runout (which should NOT be more than ~ .002". In short, it is more likely that the issues you describe are NOT due to faulty components, but rather DIRTY components or Faulty Assembly by someone who did NOT understand the concepts covered above. Most shop people (at least if owner NOT watching) installing wheels just use an impact wrench: BRRTT - BRRTT - BRRTT - BRRTT - BRRTT -- NEXT !!! NOT much attention to "Incremental - Star-pattern Tightening" with a Torque Wrench as described in TIS Procedure above. As for "Leaning", you'd better check the Lugs on the side to which leaning ASAP, and if NOT loose, then check suspension, particularly Front, ASAP. Please let us know what you find, George |
07-23-2019, 03:51 PM | #5 |
57
Rep 264
AND
Oh I forgot to post that on wide turns the car makes a clicking noise as well. Sometimes she would hear it while driving straight but that has not occurred recently.
07-23-2019, 03:54 PM | #6 |
57
Rep 264
07-23-2019, 04:18 PM | #7 | |
57
Rep 264
08-19-2019, 10:29 PM | #10 |
231
Rep 5,691
08-19-2019, 10:42 PM | #12 |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
What kind of wheels? Are they aftermarket? May be wrong hub size and need hub rings. Make sure they are balanced properly at a shop with modern balancers.
Besides that, either she needs new pads/rotors if it is shaking during braking only. I am 100% on that. Like another poster mentioned, check the control arms and all the bushings, another likely cause for general vibration.
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
08-20-2019, 08:47 AM | #14 |
57
Rep 264
Could this be the cause?
Well, heard some new clanking noises yesterday when turning the wheel so i looked and saw this rip. Seemed like a rock fell out of their too. She's going to take it to the mechanic and see what they say but does anyone know the name of this and is it dangerous to drive the car like this?
08-20-2019, 08:51 AM | #15 |
57
Rep 264
08-20-2019, 08:55 AM | #16 | |
57
Rep 264
My friend did it so im hoping Def going to change the rotors soon, just nervous about how serious this clanking noise is. |
08-20-2019, 12:35 PM | #17 | |
2697
Rep 4,031
George |
08-20-2019, 03:23 PM | #18 | |
57
Rep 264
08-20-2019, 03:30 PM | #19 |
718
Rep 1,753
08-21-2019, 10:54 AM | #20 | |
2440
Rep 4,330
clasic failing CV symptom. brake shudder is 99% chance it needs tension strut bushings. |
08-21-2019, 04:55 PM | #21 | |
57
Rep 264
Are you associating the strut brushing with the shaking because of the cv joint ? |
08-21-2019, 06:18 PM | #22 | |
2697
Rep 4,031
SOMETHING chewed it up "BIGLY" and if the rattle or other issues are also on the RF, then it would be QUITE a "coincidence" that a Rat just decided to make a meal of the CV Joint Gaiter. George |
Tags |
braking |
