Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > A/c auto mode
      07-18-2019, 11:18 AM   #1
unrulyteach
unrulyteach's Avatar
392
Drives: 2011 335i
2011 BMW 335i  [0.00]
A/c auto mode
What is the difference between these? One changes the fan speed automatic while the other stays on one speed and has to be changed manually.
      07-18-2019, 11:22 AM   #2
type-dRew
type-dRew's Avatar
641
Drives: 2009 335i xDrive
The difference between those units are limited to the one on the left being from newer car, 2010+ and having an 'all' feature so you dont have to twist both knobs to get the same temp in the cabin and then also incorporating the seat heating buttons into the unit as oppose to having them down and out of the way.
Other than that there is zero difference between them, both auto dual climate cars.
2009 335i xDrive AT / 177k+ miles
PSP 750ic / Fuel-It! Stage 1 / BMS CP / Sutphin Tuning / RFP E50
11.61 @ 117.5
New setup; Covid 19Ts on RFP 93 + ARM inlets, dp, VTT cp and PSP outlets
      07-18-2019, 11:34 AM   #3
unrulyteach
392
Drives: 2011 335i
Originally Posted by type-dRew View Post
The difference between those units are limited to the one on the left being newer car, 2010+ and having an 'all' feature so you dont have to twist both knobs to get the same temp in the cabin and then also incorporating the seat heating buttons into the unit as oppose to having them down and out of the way.
I get that but my real question is why does one adjust fan speed automatically and one has to be done manually
      07-18-2019, 12:07 PM   #4
jt335i
jt335i's Avatar
263
Drives: 2010 E92 335i Monaco blue
Have you tried reading the Climate section in pages 105 and 106 of your owners manual?
I'm sure it will explain the purpose for each control adjuster.
2010 BMW 335i: Monaco blue metallic/Premium+Sport Auto-Steptronic, BMW PE, Cobb Stage 2
2005 Mustang GT: Redfire metallic/5-spd/Ford Racing (Axle backs, silver Bullitt wheels)/K&N CAI/ Diablo Sport Predator Tuner
1997 Toyota Corolla
1983 Mercedes Benz 380SL Roadster
      07-18-2019, 12:13 PM   #5
unrulyteach
392
Drives: 2011 335i
There is nothin on those pages sir
      07-18-2019, 12:39 PM   #6
type-dRew
type-dRew's Avatar
641
sorry i didnt realize you were posting it as an issue, my fault
if thats the case, id say there might be a code in the ac system that needs to be read and fixed or cleared, because that should not be the case
11.61 @ 117.5
      07-18-2019, 12:48 PM   #7
nsjames
2440
Drives: 08 328xi Touring
because one's broken and one's not.
they should both operate teh same.
      07-18-2019, 12:48 PM   #8
unrulyteach
392
Drives: 2011 335i
It's not really an issue, i just want mine to adjust the fan speed automatically based on temp
      07-18-2019, 12:58 PM   #9
unrulyteach
392
Drives: 2011 335i
Which one is broken? And which one isn't
      07-18-2019, 01:19 PM   #10
type-dRew
type-dRew's Avatar
641
Well its an issue because it isn't working right, i just didnt understand your phrasing in the first post
I mean, at the risk of sounding like a prick, the auto climate that doesn't work automatically is the one thats broken
I set the temp in my car and let it work, no need to touch it after that
11.61 @ 117.5
      07-18-2019, 01:23 PM   #11
unrulyteach
392
Drives: 2011 335i
Ok i get that lol but does ur fan speed/intensity go up and down depending on the temperature
      07-18-2019, 01:30 PM   #12
unrulyteach
392
Drives: 2011 335i
Blank
      07-18-2019, 03:31 PM   #13
Wolf 335
Wolf 335's Avatar
2341
Drives: 2007 E92 335i
One on the left, when ON, will adjust temperature in the car based on what you have dialed in. It will try to maintain it by activating cooling or heating and fan speed.
One on the right, when ON, will automatically select whether the air is taken from outside or recirculated from inside. This is done by evaluating air quality with a sensor under your hood near the filter. There is also a sensor on your windshield that reads condensation, and when you have a foggy windshield it should activate a defrosting function.
      07-18-2019, 03:35 PM   #14
pedro2u
pedro2u's Avatar
278
Drives: '11 E93 M3 6MT, '08 E92 335Xi
Based on your Owners Manual page 118 you have to manually choose the fan speed:
Intensity of the AUTO program
With the AUTO program switched on, automatic control of the air volume and air distribution can be adjusted:
Press the left side of the (fan) button to reduce the intensity. Press the right side of the button to increase it.
The selected intensity is shown on the display of the automatic climate control.
I found your manual here:
https://justgivemethedamnmanual.com/...ith_idrive.pdf
Pete
e90yyc2425.00
      07-18-2019, 04:06 PM   #15
unrulyteach
392
Drives: 2011 335i
I wonder if it's a 5er thing, he does hav idrive screen out of the 5er
      07-18-2019, 04:19 PM   #16
hassmaschine
3973
Drives: "NBO" 330i
The one on the left is for fan speed. The one on the right is for the auto re-circulation flaps. It works pretty much the same on all BMWs from the similar time frame.
Did BMW remove the auto adjustment of fan speed on LCI cars?
      07-18-2019, 04:21 PM   #17
unrulyteach
392
Drives: 2011 335i
If it's coding idk
      07-18-2019, 04:58 PM   #18
pedro2u
pedro2u's Avatar
278
I know on my 2008 335Xi e92 that instead of hitting the fan button to adjust the intensity, you repeatedly just hit the AUTO button. So has the same effect
Pete
      07-18-2019, 06:04 PM   #19
e90yyc
Art Collector
e90yyc's Avatar
2425
Drives: 2007 328xi (GM-delete 6MT)
There is no coding involved. Nothing is broken. AUTO is still auto. My 340 had this exact setup, and I've been inside many BMW's. This is how they do things on their later models, but I have no idea when they made this switch.
The pic on the left is of a a more modern climate control system. As pedro2u already mentioned, even when in AUTO mode, you are able to fine-tune the blower "range" (intensity). Though I feel like my E90 does a pretty good job, this is a feature I sometimes miss.
Think hot sunny day. Car is a million degrees and you get in, want your AC set to AUTO, but also want to have a conversation or make a phone call. With the car on the right, the blower is going to blast your ass with air. With the car on the left, you can still leave the climate control in AUTO mode, but dial down the intensity of the blower.
Hope that makes sense.
When I'm dead, just throw me in the trash.
pedro2u278.00
      07-18-2019, 06:51 PM   #20
unrulyteach
392
Drives: 2011 335i
Yes that clears it up
      07-20-2019, 09:01 PM   #21
krhodes1
1436
Drives: 2011 328i Wagon
2011 128i  [10.00]
2011 BMW 328i Touring  [10.00]
e90yyc nailed it as to how the fan speed adjustment works on the later cars. I will add that the system is smart enough to not blast cold air when it is warming up, or hot air when it is cooling down. And it ramps up more slowly than most cars with auto climate, which I think fools a lot of people into thinking it doesn't work. And of course, if you have the adjustment turned all the way down it will barely trickle out any air to start with.
I will also add that you can code the later cars to the earlier "rest heat" function instead of ALL. That allows you to have the heat run after you shut off the car - very nice while out shopping on a cold winter's day in Maine. I did this on my car, as that is more useful to me than not having to adjust each side separately, as I never change it from 70F anyway.
What baffles me is why BMW didn't just make it modal - engine off? Rest function. Engine on, toggle All function. Seems like it wouldn't take much code to do that.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option
'11 128i Convertible - Space Gray on Savannah Beige, 6spd manual,
also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire
      07-20-2019, 09:06 PM   #22
e90yyc
Art Collector
e90yyc's Avatar
2425
Originally Posted by krhodes1 View Post
[..."rest heat" That allows you to have the heat run after you shut off the car...
Love this feature. It’s cold as f*ck where I live and in the winter this is great.
