BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Iat with stock fmic
      07-13-2019, 12:20 PM   #1
rawdog573
37
Drives: bmw 335xi
Iat with stock fmic
Been running mhd stage 1 for a while. Boosting 16psi 18 peak. Decided to bump it up to stage 1+ just to see how different it is. Boosting 20psi with no issues. Outside temp is 90 degrees. I watched my intake temps reach up to 180. Which I know is not good. I need an aftermarket fmic. But I also threw a code right at 80mph. 30ff. I had problems with it before but fixed them. If I run stage 1. I'll never see it. But stage 1+ it does it. Seems to be boosting just fine through out the rpm all the way to redline. I'm just wondering if such hot intake temps can cause the computer to thing the charge are pressure is to low?
      07-13-2019, 01:54 PM   #2
rawdog573
37
Drives: bmw 335xi
Originally Posted by kens View Post
That's way too hot to even considerably have a benefit from the extra tune, I would think.
You are most likely losing power even. You may feel more on your first WOT on a cooler engine but I know when it's hotter outside I can definitely feel the loss, even from the get go.
FMIC's are cheap and definitely enhance your cars characteristics. Get one
I know it's to hot. I just hsvnt got around to getting a new one yet. I was just wondering if hot intake temps can cause a 30ff code. Because I've literally replaced everything pretty much when I was fighting this code a couple months ago. It pulls just fine with stage 1. This code only pops up on stage 1+ when these temps get hot. Didn't know if there was any correlation or not
      07-13-2019, 02:06 PM   #3
rawdog573
37
Drives: bmw 335xi
https://f80.bimmerpost.com/forums/sh....php?t=1196862
You should log your vehicle and post here, other's will be able to help or maybe in the turbo section
https://www.e90post.com/forums/forumdisplay.php?f=58
I've tried logging. Ive even contacted mhd. My tablet won't let me upload to datazap so I tried plugging into computer ass mass storage to upload files that way. For some reason my tablet won't connect to the computer it just charges.
      07-13-2019, 02:43 PM   #4
rawdog573
37
Drives: bmw 335xi
When it's plugged into the computer, unlock it then swipe down - there should be some sort of option there to change the connection type from Charge only to "media device"
I'm also on a fire tablet 8. So I'm not sure if they makes any difference or not
      07-13-2019, 03:28 PM   #5
Bimmer_Engineer
Bimmer_Engineer's Avatar
1044
Drives: 2007 335i
i'm on a fire 8...i upload to MHD by emailing the data file to my gmail and then uploading on a PC.
      07-13-2019, 03:29 PM   #6
rawdog573
37
Drives: bmw 335xi
How do you do that from the app
      07-13-2019, 06:45 PM   #7
Bimmer_Engineer
1044
Drives: 2007 335i
Don't use the app. The data log files are saved in the documents section on your fire tablet. Just go find the files and email them using webmail...
