Rein Coolant Expansion Tank
07-08-2019, 09:09 PM | #1 |
13
Rep 63
About 6 months ago my factory coolant expansion tank cracked and spewed coolant all over the left side of my engine bay. I replaced it with the Rein tank from FCP Euro and had no issues till last week. Before leaving on a 3 hour trip Wednesday I added a little coolant to get just below the max (still within the tolerance). After about 50 miles, the Rein tank cracked and left me stranded. I ordered another to replace it this week and upon receiving, I noticed the Min/Max inside the tank can flex up and down. Has anyone else noticed this? I’m curious if I overfilled the tank as I was just below max, especially if the Min/Max indicator lifted up and read lower than actual.
07-08-2019, 11:17 PM | #2 |
Art Collector
2425
Rep 3,448
Can’t comment specifically on the Rein tank, but why were you topping off your coolant? Was there a leak, and do you happen to recall how much coolant you added?
When I'm dead, just throw me in the trash.
07-09-2019, 09:19 AM | #3 |
13
Rep 63
I topped it off because I was traveling 3 hours away, just didn’t want to run on minimum coolant. No leaks that I can see. I added no more than a cup or two of coolant. I have it premixed in a gallon jug, didn’t pour enough to really even notice a difference in the gallon jug.
07-09-2019, 12:29 PM | #5 |
398
Rep 1,579
Did you replace your cap when you replaced the tank? A bad cap can over pressurize the system. OE caps are under $20.
The min max is a floating stick. It will clank around when empty. |
