Wipers; no function; been searching threads, no joy
07-08-2019, 02:33 PM | #1 |
Rep 60
Wipers just won’t turn on. Washer motor functions. Fuses look good. Relay clicks. About to check motor for power
I don’t know if the relay (the green one) could be clicking but still malfunctioning. Also concerned because someone else had power at the motor but no function and they swapped the motor (logically) to discover it was something else. Sounds weird, but they do weird things with auto sensors and brake drying so who knows Thanks 2008 328xi Last edited by 3srsntswngr; 07-08-2019 at 03:35 PM.. Reason: Gramar |
07-08-2019, 07:14 PM | #2 | |
743
Rep 1,096
Drives: '01 Z3M, '12 335is, '22 540i
Garage List 2012 BMW 335i [5.25]
2012 BMW 335is [5.00] 2008 Infiniti QX56 [0.00] 1967 Chevrolet Corv ... [10.00] 2001 M Roadster [10.00] 2022 BMW 540i [0.75] 2009 528i [9.50] |
https://www.fcpeuro.com/products/bmw...or-61617161711 Took about an hour or so. |
07-09-2019, 01:50 PM | #3 | |
Rep 60
07-09-2019, 07:30 PM | #5 |
654
Rep 1,893
To directly answer your question, yes, a relay that clicks can still be malfunctioning. Pretty easy to test with a multimeter and a source of 12V power (battery) as is the wiper motor itself.
Check out wiring diagrams here: https://www.newtis.info/tisv2/a/en/e...inputs/upOxh9C I'm usually in favor of testing components where possible rather than guessing about replacement. But in this case, the relay is only about $16 and a new washer motor (without linkage) is about $56 at Rock Auto or equivalent (a lot less than the $420 that FCP wants for a new OEM motor/linkage assembly). |
07-09-2019, 08:35 PM | #6 |
2440
Rep 4,330
a powerprobe is possibly one of the greatest electrical diagnostic tools I ever added to my toolbox.
look into it. Makes it dumb easy to diagnose things like this. Jab it into the relay load terminal and apply 12V to the motor right there and see if it turns on. |
07-09-2019, 09:33 PM | #7 |
Rep 60
Thanks for the useful responses. Was planning to try the new relay. I saw a link to the Napa part somewhere in my forum searches. I’ll try to remember to report anything worthwhile
Good idea on the power probing |
07-09-2019, 10:00 PM | #8 |
654
Rep 1,893
Got a link for this?
07-10-2019, 03:04 PM | #9 |
2440
Rep 4,330
07-11-2019, 11:14 AM | #10 |
126
Rep 482
Here is an old post on an older model BMW. It might help. Those cars preserve the basics throughout many years, just cosmetically enhanced.
Stable:
e92is f25 N52 e83 N52 e46ci M54B25 (e53 N62 - sold, R.I.P. e39 M54B30) |
07-11-2019, 12:37 PM | #12 | |
654
Rep 1,893
ECH AR6250 https://www.napaonline.com/en/p/ECHAR6250 Last edited by dpaul; 07-11-2019 at 12:42 PM.. |
07-14-2019, 07:33 PM | #16 |
Rep 60
07-15-2019, 12:06 AM | #18 | |
2697
Rep 4,031
https://www.newtis.info/tisv2/a/en/e...inputs/upOxh9C Fuse F50 (1st thing to check ;-) Installation Location (beneath relays): https://www.newtis.info/tisv2/a/en/e...lim/1VnYh5CO3E Relays K36 & K37 Installation Location: https://www.newtis.info/tisv2/a/en/e...lim/1VnYuo3ZrW Automotive Relay Pin Configuration with Pins 87 & 87a (5-pin). NOTE the 85 & 86 electromagnet pins are parallel & opposed to each other and pins 30 (battery) & 87 (contacts closed output) are perpendicular to each other: https://www.delcity.net/documents/au...ay_diagram.jsp Please let us know what you find, George |
07-15-2019, 07:06 PM | #19 | |
Rep 60
07-15-2019, 07:34 PM | #20 |
Rep 60
Jumped what I believe to be pin 30(3) to 87a(5). Should have turned on the wiper motor I think, no? I tried 87(4) also.
Fuses were checked first thing Bad motor? Short? The switch and relay should be bypassed by the jump? |
