N54 HPFP disaster
07-04-2019, 02:42 PM | #1 |
Rep 2
N54 HPFP disaster
Hello all!
For a while I’ve been neglecting replacing my HPFP on my 2007 e90 335i mostly due to cost and time. I finally got around to doing it. I didn’t want to stress myself out by trying to cram my massive hands underneath the intake manifold so I bought the intake manifold gaskets so I could just take it off altogether. In the process I removed the alternator cable and accidentally shorted it out against the body of the car. I didn’t think much of it. Eventually I get everything put back together and upon first start, it takes nearly 5 seconds of cranking before it turns over which i just figured was because of the pump not having any fuel. As soon as the car starts I am greeted with: Very rough idle Immediate check engine light Transmission malfunction light (reduced acceleration) The codes given were: 29D0: combustion misfires cylinder 4 29DC: cylinder injection cutout 29F2: fuel high pressure system, fuel pressure 29F3: fuel low pressure sensor, electric 2A17: dmtl System fault 2A94: crankshaft sensor, signal 2E68: knock sensor signal 1 2E8E: intelligent battery sensor, missing 30FF: turbocharger, charge air pressure too low 3100: boost pressure control deactivation I tried clearing the codes and starting the car again with no luck I reinstalled the old HPFP, no luck I triple checked everything was plugged in, no luck My real question is: has anyone encountered this before? Could I have possibly blown a fuse from shorting the alternator cable? What should I check? Thanks in advance for any help! |
