Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Any inputs, any guidence
      07-04-2019, 02:19 AM   #1
BimmerG0d
Drives: Bmw 328xi
Hi guys, I知 new here and would like to get some input or get guided to the right direction with these problems I致e been breaking my head over. I just got this 2007 bmw 328xi auto about 2 months ago, so far I changed the valve cover gasket, a few vacuum lines, the 4x4 actuator gear, all fluid change( transmission, oil, both differentials, transfercase), serpentine belt, a lower coolant hose and today did the charcoal filter delete. So far I知 almost to where I want it to be. Car runs strong and some what smooth. At times I get a little kick or jerk when taking off from a stop, RPMs stay the same when this happens just a - - - and go. I reset the adaptations with tool32, reset the oil life on the transmission and transfercase. And it feels a lot smoother and jerks happen less often. Now I知 trying to update all the modules on the car and so far I致e got most of them updated, except the EGS- 7572763, Dme-7573452, Mostgw- 9130347, Mask/ccc- 9132212, and the FRM- 9128183. When I use Winkfp it shows the current number and update number the same. On my user information field read out those modules haven稚 been updated since 2006. I have the current sp-datens and updated Winkfp with them. I知 not sure what to do, are they really up to date or I知 I doing something wrong? Please guys enlighten me. Many blessings to all.
      07-06-2019, 12:50 AM   #2
BimmerG0d
Drives: Bmw 328xi
Not one reply? Did I post in the wrong section?
      07-06-2019, 01:35 AM   #3
ctuna
1911
Drives: 325xi 06 wagon MT
Go to the coding subforum for update questions.
Usually there is little to be gained by updating modules.
The i level of the car indicates it's firmware level
easier to read in Ista D. They give both the factory ilevel
and the current ilevel.
It can be dangerous to update with ISTA p unless you have
a solid icom cable and a big power supply.
https://www.e90post.com/forums/showthread.php?t=1596943
The following chart relates ilevel to the daten level in inpa ista
https://www.google.com/url?sa=t&rct=...lkXEhlQYy4i9Nb
https://www.bimmerfest.com/forums/ar.../t-657682.html
      07-07-2019, 09:00 PM   #4
BimmerG0d
Drives: Bmw 328xi
Thanks for the reply, I値l check out the links and I値l keep that power supply in mind.
My I Level is: e89x-06-09-540.
Tags
update, winkfp
