Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Mirror adjustment
      06-28-2019, 06:11 PM   #1
Itsmeveee
Drives: E90 320d msport
Mirror adjustment
This is a bit annoying ,
Everytime I switch the car off , the passenger side side mirror switches to a random position , and doesn't go back to my setting when i start the car , I have to re adjust it manually.
The seats + driver side mirror stay the same , no movement.
I've tried to on and off the go back to last position option in the settings menu...
Could this be a faulty motor in the mirror ?
      06-29-2019, 01:45 PM   #2
Jagtem
Jagtem's Avatar
26
Drives: 2006 330i / 2004 F150 /2009 R1
Are you talking about the mirror glass, or the complete mirror/ folding assembly? I believe there are known faults/ fixes for both issues.
      07-03-2019, 03:51 AM   #3
Itsmeveee
Its just the glass that moves
      07-03-2019, 08:10 AM   #4
jt335i
jt335i's Avatar
263
Drives: 2010 E92 335i Monaco blue
I had experienced something similar, but not sure if this is the same thing.
Whenever I reverse to back up and park, the passenger side mirror glass tilts down normally as it typically does as part of the PDC. And when I put it in park, the mirror is supposed to adjust itself back to where it was before, however I started noticing it hasn’t been doing that and ends up in a random position which forces me to readjust it.
Now I figured out that if the mirror adjust slider switch is set to the left (driver side adjust) this passenger side mirror random position adjust occurs. But if I leave the slider switch set to the right (passenger side adjust) the mirror remains in the position where it’s supposed to be so I just keep the switch to the right. I’ll test it again just to be sure.
Hopefully this will work for you.
2010 BMW 335i: Monaco blue metallic/Premium+Sport Auto-Steptronic, BMW PE, Cobb Stage 2
2005 Mustang GT: Redfire metallic/5-spd/Ford Racing (Axle backs, silver Bullitt wheels)/K&N CAI/ Diablo Sport Predator Tuner
1997 Toyota Corolla
1983 Mercedes Benz 380SL Roadster
      07-03-2019, 12:45 PM   #5
djh2
68
Drives: '16 330e
2007 BMW 328i  [0.00]
OP Check out this post: https://www.e90post.com/forums/showthread.php?t=683764
      07-03-2019, 04:11 PM   #6
SlimE92
SlimE92's Avatar
No_Country
186
Drives: E92 N54
Whenever I reverse to back up and park, the passenger side mirror glass tilts down normally as it typically does as part of the PDC. And when I put it in park, the mirror is supposed to adjust itself back to where it was before, however I started noticing it hasn't been doing that and ends up in a random position which forces me to readjust it.
Now I figured out that if the mirror adjust slider switch is set to the left (driver side adjust) this passenger side mirror random position adjust occurs. But if I leave the slider switch set to the right (passenger side adjust) the mirror remains in the position where it's supposed to be so I just keep the switch to the right. I'll test it again just to be sure.
This is not a "fix". With the switch set to the right the passenger mirror glass does not tilt when reversing to park you lose the function unless it's set to the drivers side.
Tags
320d, e90, mirror
