Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Style 162 square setup
      06-28-2019, 10:08 AM   #1
portlandareae28
Drives: 335i
Hey, I am curious if anyone knows if I can run style 162's all the way around with 255/35/18 all the way around? or? I want to keep a clean stock look on the car but I would like some more bite up front.
Thank you
      06-28-2019, 11:05 AM   #2
Rmtt
Rmtt's Avatar
8211
Drives: 2011 BMW 128i, 2008 LS3 C6
Thank you
Not sure what the offset of those wheels are.
My current wheel (Apex) has an et of 45...and I am running a square 245/35/18 setup with a factory "M-Sport" suspension.
That's the most aggressive tire they recommended that I could run stock without having to do anything such as suspension/fender, or spacer work.
But that is also on a "1" series.
Everybody has a gameplan....until they get punched in the mouth.
      06-28-2019, 11:11 AM   #3
spak888
spak888's Avatar
119
Drives: '19 M2C,'07 335xi, '11 335ix
I had the same idea and placed the 255/35/18 Michelin Pilot Sport AS3, 18x8.5 Style 162 in the front for a test fit and it ended up too close to the front suspension for my comfort. I ended up doing 235/40/18 on the 18x8 fronts all around with 15mm spacers in the rear to maintain the OEM staggered look. 335xi lowered on Koni Yellows and OEM ZSP D7/D6 springs. See photos for reference.
      06-28-2019, 11:34 AM   #4
portlandareae28
Drives: 335i
[QUOTE=Rmtt;24968023]Not sure what the offset of those wheels are.
they are ET37
      06-28-2019, 01:17 PM   #5
Gamb1t
Gamb1t's Avatar
598
Drives: 330i,X1,Z4,Solstice GXP, RX-8
Putting a heavier tire wheelset up front with affect steering feel and of course grip dynamics. I'm referring to the rwd e90s.
      06-28-2019, 01:57 PM   #6
dwashy
65
Drives: 2006 E90 330i
255's would be pretty close. I run 235's up front and they will rub if I'm too low. I've got pretty mad camber too to compensate for the increased size
N52 | +1mm MILVs | Catless | 3-Stage IM | BPC Tune | 3.64 diff | AirLift Performance 3H | M3 Control Arms | SPL Parts BumpSteer Correction | UUC Evo 3 Shifter | CCV Delete | Valeo SMF Flywheel | CSF Aluminum Rad | VAC Front Hub Extenders | BMS Cowl Filter Delete
      06-28-2019, 02:00 PM   #7
portlandareae28
Drives: 335i
I will do some more digging, I know on my E36 M3 the euro cars did not come staggered, they were only staggered for the US market. The car became so much better once it was squared up. Not sure on e90's if this was the same case
