BMW Z4 Forums (G29) BMW Z4 (G29) General Forum G29 Z4 Wind Deflector Retrofit Guide
      06-21-2019, 01:42 PM   #1
J400uk
J400uk's Avatar
76
Drives: 2023 840i Convertible
So I made the mistake of ordering my Z4 without the wind deflector from the factory. I've retrofitted it this week and thought I'd post a guide.
First advice, if you haven't yet ordered your Z4 it is much easier just to tick the option! It is much cheaper from the factory (just £170 in the UK or bundled with the comfort pack) and saves a lot of hassle.
However if you've already ordered or have picked up a used G29 without then read on...
The following parts are required and are pictured below:
  • [1] Wind Deflector (54 34 9 481 141) £197
  • [2] Windschott (54 34 7 457 891) £110 x2
  • [3] Trim roll b (51 46 7 459 683) £26
  • [3] Trim roll b (51 46 7 459 684) £26
So total price comes in at £469 in the UK, £300 more than the factory! I decided to skip out on the 'Windschotts' to keep the price down, as you can still fit the deflector without.
Step 1 - Remove the rear cover from the hoops. A little force may be needed but it will just pull out and unclip
Step 2 - Unscrew the front cover from the hoops. This is otherwise the item known as 'Trim roll b' in the diagram and requires replacing the wind deflector compatible version. You will need a Torx T15 screwdriver for this. 5 screws
Step 3 - You'll then be left with the bare hoops. Follow the reverse of Step 2 and screw on the new front covers.
Step 4 - Reattach the rear covers and insert wind deflector! Job done
Here is a photo of the finished result and another diagram showing how it all clips together:
Hope this helps! The wind deflector is certainly well worth having and at highway speeds makes a huge difference to refinement, I'm extremely pleased with it
Appreciate 6
CeEl479.00
JustChris17487.50
Amadeo391.50
Timdon161.00
      06-21-2019, 02:38 PM   #2
PrionFawkes
127
Drives: G29 Z4 M40i (2020)
While I'm not the target audience of this guide, I think you did an excellent job and I know it will be very much appreciated.
*Even if the only step they follow is ordering the option to begin with.
JustChris17487.50
      06-21-2019, 07:56 PM   #3
Ex_Stig
Ex_Stig's Avatar
2594
Drives: '24 X7 M60i
2024 BMW X7 M60  [10.00]
I didn't even see this as an option when specing our the Z4. Did I miss something?
Ex Stig
'25 M5 Touring (on the list, first slot)
'24 X7 M60i
'22 M5 CS - (sold)
      06-21-2019, 09:43 PM   #4
German1967
German1967's Avatar
583
Drives: 2015 M235xi - 2022 992 C2S Cab
In the U.S. it is standard.
Hoc Lapidem Non Vi Sed Saepe Cadendo!
Appreciate 3
Ex_Stig2594.00
      11-15-2021, 01:13 PM   #5
jones89olorin
Drives: BMW Z4 G29 sdrive20i
Hi all, does anyone know how to get the covers off, as described in step 1? Do you try to pull them off in a vertical direction, or horizontally? Any tips?!
Thanks!
      03-27-2022, 09:58 AM   #6
hassand
Drives: G29 BMW Z4 M40i
Would you please re-upload the photos. I need to do this to my G20 Z4
      05-03-2022, 08:09 AM   #7
SRCTG29
Drives: BMW Z4 g29
Just re starting this thread to get tips on removing the rear covers - help appreciated
      05-04-2022, 02:54 PM   #8
SRCTG29
Drives: BMW Z4 g29
Got the replacements and see it’s just a matter off popping them off horizontally cheers
      04-23-2023, 10:36 AM   #9
Ex_Audi_S3
Drives: bmw z4m40i
OP were you in the UK? If so where did you find the parts? I’m in desperate need of this. I’m trying to get the black version of the backing
      04-23-2023, 01:36 PM   #10
Timdon
Timdon's Avatar
161
Drives: BMW z4 g29
Looks excellent a job well done , I decided to fit the windschott glass wind deflector , also a good place to fit the rear camera.
Appreciate 3
stlcdr1011.50
crz4859.50
bmw
