06-13-2019, 03:38 PM | #1 |
BMW obsessed
9587
Rep 10,878
IND | Future Classic Wheel Spacer Kit
As BMW has made the switch over to a 5x112 bolt pattern, Future Classic took it upon themselves to inject the winning philosophy behind our 5x120 spacers into this new PCD. Visually, the 5x112 spacer has marked differences from the 5x120 variant—the hub bolt holes (specifically placed for the F90 M5) have been implemented within bespoke cavities. The pocketing has been placed strategically as well to mimic the cutouts on the F90 M5's OE wheel. Just like their 5x120 version, the 5x112 Future Classic wheel spacer is not only a visual treat but a marvel to handle—its machining and finishing work reflects our commitment to detail, every piece of it feels engineered and massaged to the tightest tolerances. To create the most complete wheel spacer kit, Future Classic has painstakingly sourced a complimentary suite of products that are included in every box—four hub bolts, race worthy Copaslip copper anti-seize, an anti-seize applicator brush, and of course, wheel bolt hardware. Echoing Future Classic’s racing enthusiasm, the first “livery box” set is fashioned in motorsport design, the Porsche variant wearing the infamous “Pink Pig” garb whereas the BMW box is adorned with the iconic Frank Stella 3.0 CSL art car print. Across FC's product line, the boxes wear different designs to give customers a little backstory to the liveries before their eyes, a detail that breathes Future Classic through and through. Product Details:
Future Classic Wheel Spacer Kit may be viewed at the following link to our online store: https://ind-distribution.com/collect...eel-spacer-kit Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com
10-25-2019, 03:18 PM | #3 |
2868
Rep 11,374
11-05-2019, 09:45 AM | #4 |
BMW obsessed
9587
Rep 10,878
Always keep improving.
Future Classic has come out with a new version of their popular 5x112 spacer as pictured directly above V2 has managed to shave extra weight off of the initial version with larger pocketing areas while also incorporating a slotted hub bolt section. This change allows both non-M and M models to bolt the spacer to the hub (whereas V1 was M-specific only). FC's V2 5x112 spacer is in stock in both 12 and 15mm sizes for F90 M5
04-03-2020, 08:18 AM | #6 |
Just A Regular Guy
318
Rep 242
Drives: G80 M3 Competition X-Drive
04-20-2020, 04:30 PM | #7 |
BMW obsessed
9587
Rep 10,878
Yes absolutely you will be fine. The 5mm still leaves an adequate amount of OEM hub area to use whereas larger spacers occupy more...space. 10mm is a common spacer where hubcentric "extensions" appear. This is largely because OEM hub heights are 10-11mm. As a result, manufactures add the hubcentric section to restore the necessary surface area to mount onto.
Burnsey318.00 |
