06-03-2019, 01:44 PM | #1 |
Rep 4
Winter wheel and tires sizes for the M340i?
I have a 2020 M340i xDrive with OEM 19” staggered wheels. I’m looking at sizing down for winter wheels and going with a square setup.
- Will 18” wheels even fit over the M Performance brakes? I believe OEM are 18”x8” with a +20 offset. - Would 18”x8.5” with +20 offset wrapped in 235/45/18 or 245/40/18 work? |
06-19-2019, 11:54 PM | #3 |
5248
Rep 5,874
I'm looking at 245/35/19 square if they'll fit in the front. Alternatively I may go with OEM sizes but will personally only go with Pirelli Sottozero 3 or Michelin PA4 so depends on sizes and what actually fits. For wheels I'm leaning toward VMR V810. My car arrives in August so I won't be able to sort this out much until then. I don't think there have been many test fit wheels/tire combos at this point.
09-03-2019, 12:56 AM | #4 |
5248
Rep 5,874
Bumping this up because I'm having a difficult time finding decent aftermarket wheel fitment with the relatively low offset OEM front wheels.
Anyone have a winter set figured out in staggered OEM spec or near to it? |
09-06-2019, 09:12 AM | #5 |
47
Rep 82
Watching this thread too.
Staggered 19's PS4S's here but I have ZTK, so brakes are an issue. AFAIK, 18's will not fit if you have ZTK. I'm close to ordering wheels & tires for winter as well. I'm new to needing aftermarket wheels, but from way too many hours of research on TireRack, I'm somewhat close to going with some 225/40 R19 tires and some Flow One Race Spec 19x8.5 ET32 wheels. Those are about as close to square-OEM as I can find for a reasonable but decent looking winter-wheel setup. But I'm not 100% on the front clearance since willtheyfit calculates like 11mm closer to the suspension, which sounds awfully tight with those big front calipers... Last edited by Delta5; 09-25-2019 at 09:04 AM.. |
09-07-2019, 10:55 PM | #6 |
5248
Rep 5,874
From what others have said, front wheel offset is ET27 so ET32 with same size tire is only 5 mm closer. The rotor won't matter but the caliper might. There are only about 5 mm space between my 792M and standard M calipers. I think I'm going to go with an ET30 wheel but I don't know.
09-09-2019, 12:40 AM | #7 |
5248
Rep 5,874
I've narrowed it down to 19x8 et30 all around with 235/40/19 tires. I'm going with MSW type 73 wheels and Pirelli Sottozero 3 tires. After measuring the OEM fitment with 792M staggered, I think you could fit a square setup with offsets between 25-35 depending on tire widths.
wtcantfw0.00 |
09-11-2019, 01:15 PM | #8 |
General
2038
Rep 25,989
We actually just made a special batch of 19x8.5 ET25 V710's for our friends with G20's! Shoot me a PM and we'll see what we can work out if you're still looking for a winter setup!
09-16-2019, 03:07 PM | #9 | |
47
Rep 82
09-20-2019, 07:44 PM | #10 | |
1110
Rep 2,008
09-25-2019, 09:11 AM | #12 | |
47
Rep 82
I've been looking at Enkei Raijin (19x8) and running a square setup or BBS SX's (19x8.5) and keeping staggered. Or reaching out to VMR above . But not sure about choices; 225/40's on the rear looks a little weak and 225's are too narrow for 8.5's in the front. I hadn't considered MSW, but 235/40 on 19x8 square setup for winter sounds about perfect. Last edited by Delta5; 09-25-2019 at 09:18 AM.. |
wtcantfw0.00 |
09-29-2019, 04:13 PM | #13 | |
12
Rep 82
I'm looking at purchasing new M340 xDrive with ZTK (which includes 791M high-performance non-RFTs (Front: 19x8.0, 225/40 R19, Rear: 19x8.5, 255/35 R19). CA and service team stated the following winter 18" wheel and tire *should be* compatible. Very interested to hear if this setup actually works as well as other winter wheels/tire options available.
M Performance 18 inch Style 796M Black Cold Weather Wheel & Tire Set - Front 36112462648 M Performance 18 inch Style 796M Black Cold Weather Wheel & Tire Set - Rear 36112462649 Quote:
09-30-2019, 11:53 AM | #15 |
General
1566
Rep 29,202
Here the M sport brakes are standard along with 18", so I don't see why it would not fit.
10-03-2019, 12:28 PM | #16 | |
12
Rep 82
10-05-2019, 11:54 AM | #17 | ||
General
1566
Rep 29,202
10-06-2019, 01:14 PM | #18 |
933
Rep 4,325
Drives: M340
Why don't you guys consider 18" 790M wheels if you do not have the track pack.
I am loving the ride on my M340 and they actually look pretty cool. One the best decision I made while ordering my car. I am also loving the non RFTs.
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
10-08-2019, 05:50 PM | #20 | |
5248
Rep 5,874
Delta547.00 |
10-08-2019, 09:30 PM | #21 | ||
47
Rep 82
