2008 BMW 328xi Transmission
05-30-2019, 11:56 PM | #1 |
24
Rep 119
I have a 2008 BMW 328xi, bought the car new back in 2008 and she's still my baby. Never had any serious issues. But my car now has 170,000 Miles. I hear the transmission usually starts to fail around 150-200 thousand miles. My transmission still seems to work fine. Every now and then I get a rough feeling shift but that's about it. Do you guys think I'm going to have to replace my transmission soon? I've seen some used ones on eBay with under 80,000 miles for under 1000$ USD. How much do you think a shop would charge for them swapping out my transmission for one I give them.
05-31-2019, 08:09 AM | #2 |
Hoonigan
6848
Rep 3,000
Drives: '09 328i, '98 Wrangler
Where did you hear the transmissions start to fail around 150-200k? I've never heard that, and there are quite a few on here with 200k+.
Have you ever changed the fluid and filter? I would start there, and recommend Valvoline MaxLife Synthetic for the GM 6L45 transmission.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
05-31-2019, 08:21 AM | #3 |
Art Collector
2425
Rep 3,448
Mine has nearly 200k miles on it and is definitely on its last legs, but it was quite low on fluid at one point, and I’m pretty sure I made the problem worse by changing some components in the valve body in an effort to improve things.
No need to replace it unless you’re really bothered by its performance I have my doubts the dealership will want to install a unit you provide. Even if they would, I’d suggest taking it to a reputable transmission shop or indy for the install instead. As CT mentioned, try fluid/filter first and then go from there.
When I'm dead, just throw me in the trash.
05-31-2019, 10:40 AM | #4 | |
24
Rep 119
05-31-2019, 10:43 AM | #5 | |
24
Rep 119
06-08-2019, 09:51 PM | #7 |
24
Rep 119
06-08-2019, 10:25 PM | #8 |
Hoonigan
6848
Rep 3,000
Change the fluid.
06-21-2019, 07:20 AM | #9 |
General
17314
Rep 18,737
For the E90, BMW states to change the automatic transmission fluid at 100,000 mile intervals. It is stated in the maintenance booklet that comes with the original set of manuals in the trunk.
