Driving W/O a Passenger Seat
05-30-2019, 06:45 PM | #1 |
Rep 3
I am looking to replace the 'passenger awareness' sensor in the shotgun seat. The seat may be physically out of the car for a day or two. Will the car throw codes that requires me to go to the dealer / indy to reset with the seat being disconnected while I drive?
05-30-2019, 11:02 PM | #3 |
Art Collector
2425
Rep 3,448
There’s no need to go to a mechanic for this. This is something you can do yourself.
If you aren’t keen on installing software and buying a cable (least expensive route), invest in a scan tool. It’ll pay for itself the first time you use it. Good luck!
When I'm dead, just throw me in the trash.
05-31-2019, 06:27 AM | #4 |
Rep 3
The faulty sensor code goes away after time. It really only gets triggered once someone sits in the seat. I was more interested in if there was a more permanent fault that goes off if there is no seat detected at all.
I've seen the scan tools that are licensed per VIN, I may look at one of those if my OBD-II tool doesn't fix the situation when [if] time comes. |
05-31-2019, 08:24 AM | #5 |
12
Rep 51
I have the same issue. Dont worry, you'll be fine. In true German fashion you'll have like 7 - 10 warning lights about the imminent danger your non existent passenger is in, but they'll go away when the issue is resolved. Have you thought about a seat mat bypass?
06-02-2019, 07:53 AM | #7 | |
398
Rep 1,579
06-02-2019, 08:50 AM | #8 |
654
Rep 1,893
It's pretty straightforward if you have BMW standard tools installed on your laptop and have a decent DCAN cable
Use NCSExpert to code out the passenger seat occupancy sensor in the ABG module by setting OC3 to nicht_aktiv. Remember to clear errors with INPA afterward. |
