Precursor: 335i DCT Conversion
05-29-2019, 06:21 AM | #1 |
29
Rep 383
Hey all, Brian here. I've got a 2011 N55 M-Sport and I'm nearing 120k miles.
So I've read a few threads here and there on forums E90post and others: so a DCT conversion is possible on the E90 335i platform? I've been driving my E90 for a while now and I've come to familiarity on the character of the car. Coming from 4 cylinders, this 3L i6 turbo definitely has some oomph to it, less that be an understatement (especially on tuned units). Sadly during my journeys with this car I've come across issues with its transmission: faults started becoming true and lights start showing and the transmission's begun to slip and trip. It looks like it's on its way out at its end of its mechanical trueness. I've pondered upon the idea of having a concurrent version of the famed N54 legend, the 335is, in a four door flavor, and the word with its subsequent abbreviation "DCT Conversion" comes to mind. It appears some have successfully bred a so-called "E90 335is", if you will. Upon reading the bits of information shared from the generosity from those of success, it seems the mechanical and practical portion of such an theoretical "project" is one of a tangible reality. My latter notions are of concern with the technical complexity regarding the computer and software side of things. So at the end of it, I've come to a conclusion that I indeed would like to embark on the exciting and possibly long and treacherous journey of executing and completing a Dual Clutch Transmission Conversion of my N55 E90 LCI M-Sport, ZF 6AT. I know it is a consciousness of many questions and challenges. How much of a reality do you think this could be? ...pending continuation... Your thoughts and input would be greatly appreciated. -Brian |
05-29-2019, 10:38 AM | #3 | |
1458
Rep 1,912
06-07-2019, 04:26 PM | #4 | |
29
Rep 383
Glad it's on its way. I'm sure it's only the drive logic part that's in the way. Maybe you can lend me a hand when I start my conversion. |
06-07-2019, 04:47 PM | #5 |
2124
Rep 2,758
It's definitely possibly, hardest part would seem to be the coding work that will need to be done, maybe a little wiring too. I am definitely interested in swapping a DCT into my car also in the future, when my auto completely gives out.
Subscribed. |
06-07-2019, 09:06 PM | #6 | ||
27
Rep 290
06-07-2019, 09:08 PM | #7 |
27
Rep 290
I plan on doing this in the future so would like to learn as much about it as possible. I don't care about the drive logic as long as I can put the car in manual mode on the most track based tranny logic as possible and be able to put the trans in neutral and reverse and such
06-10-2019, 10:47 PM | #8 |
19
Rep 68
Hi. Interested in the swap. I got a dtc/flywheel/harness/cooler for cheap.. just to have options if the 6hp2q give up.
Is it the same way to code the 6hp21 to alpina flash? But to the m3 gts software with my vin? What is the m3 gts software # please? |
