N54 Upper Radiator Hose "Plastic Gasket"
05-26-2019, 08:40 PM | #1 |
Rep 8
I can't find this piece for my 335 ANYWHERE online or in store. It's for the upper radiator hose that goes into the oil filter housing. It's a little plastic ring that slides onto the housing itself. Without it the quick clamp on the hose is basically no good I lost mine while getting to the alternator. It's Memorial Day weekend and I'd rather not wait till Tuesday she's already been sitting two weeks! If anyone has any idea what this little ring is called or a part number that'd be greatly appreciated. I've got the o-ring looking for the plastic piece, it goes underneath what I circled. [IMG][/IMG]
Mark
05-26-2019, 08:49 PM | #2 |
2007 335xi
31
Rep 69
hey I went to realoem.com put in car info they have diagrams for most everything..
this is mine 2007 335xi oil filter housing o-ring 11537545278.. Also I have o-ring viton kit and another one I got from harbor freight one would maybe fit think 29x2
2007 335xi Daw stage 2 old wheel custom 2.25 relocation inlets vrsf alum outlets.Vrsf 5'' stepped intercooler.stage 2 bucket lpfp.BQ tune xhp stage 3 tranny flash.vrsf downpipes modified 3in exhaust.ER charge pipe tial bov.Custom oil cooler..cic retrofit.koni shocks h@r sport spring staggered conti tir
05-26-2019, 09:11 PM | #3 |
Rep 8
I'm looking for the plastic piece
Mark
05-27-2019, 06:43 AM | #4 |
General
17315
Rep 18,737
The plastic connector is not sold separately. You have to get a new hose.
05-27-2019, 07:50 AM | #5 |
319
Rep 1,023
Correct; it's part of the hose.
p/n 17127540127 #10 on this part schematic FCP Euro has both the BMW and Rein (claimed OEM supplier) versions for sale. They come with the internal o-ring.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
05-28-2019, 10:31 AM | #6 |
2440
Rep 4,330
05-28-2019, 10:52 AM | #7 |
Hoonigan
6848
Rep 3,000
Drives: '09 328i, '98 Wrangler
+15 on needing the whole hose
Also looks like your oil filter housing gasket is leaking.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
05-28-2019, 11:12 AM | #8 | |
2440
Rep 4,330
may as well when doing the gasket. I worked around it, but later replaced that coolant fitting because it just looked terrible, and was sketchy. Crumbled as soon as I touched it to remove it. o ring is slightly larger, you need to lube it with some coolant to get it to go nicely. edit: I didn't see that the price is now $18. When I ordered it was like$12. I'm sure you can find it cheaper on ebay or whatever. |
