What does this mean? Terminal 87_1 No Voltage,
05-25-2019, 09:07 PM | #1 |
Rep 6
Drives: 2013 335i & 2006 328i
I'm getting the fallowing codes, does anyone know what they mean?
2013 335i N55 EWD DME Interface fault Terminal 87_1 No Voltage, O2 Sensor heating after catalytic activation short circuit to earth Wastegarte Shorted to earth Last edited by Bimbobway; 05-25-2019 at 09:15 PM.. |
05-29-2019, 07:51 AM | #2 |
Rep 6
So I figured it out, it was simple. I found a blown 20 amp fuse, so my thinking is terminal 87 was missing voltage and it was common to both O2 sensors and the waste gate control. Put a new fuse in and the codes cleared.
05-29-2019, 04:44 PM | #3 |
2440
Rep 4,330
that's exactly it. terminal 87 on a relay is for the voltage source.
30 is load 85-86 are the coil. I'd check for o2 sensor wires that are damaged. sometimes they short on the manifold. |
05-29-2019, 06:47 PM | #4 | |
2697
Rep 4,031
If you look at TIS circuit diagrams, when there is "30" above a fuse, it's Battery powered (NOT relay-switched), and when "87" is above the fuse, it is "Relay-activated." As example, here is the O2 Sensor circuit for your 2008 328xi; NOTE the "87" above the symbol for fuse F38 (30A): https://www.newtis.info/tisv2/a/en/e...ontrol/vF5QqMj Here is the F38 circuit diagram (for your 2008 328xi) that shows the entire power supply circuit, including the DME Relay (K6300) that supplies power to the F38 socket in the JB. https://www.newtis.info/tisv2/a/en/e...xi-tou/vFbq6N3 I'm NOT sure what fuse OP is talking about, or WHAT the actual codes were (he just gave Code Definitions & NOT actual codes). The TIS circuit diagram shows the two O2 Sensor heaters (pre-cat & post-cat) both powered by the DME and NOT a dedicated fuse (he didn't give fuse #, JUST 20A rating. Perhaps he looked at an N54 schematic? https://www.newtis.info/tisv2/a/en/e...ntrol/CkQHyyQ2 Fuses are Downstream of the relay (pin #87), or between the relay and the "load" or electrical component, as the relay is supplied with battery power. Can't learn much from this thread to date, except maybe that we need to learn how to find & read TIS circuit diagrams. George |
06-12-2022, 11:08 PM | #6 | ||
Rep 6
Drives: E90 n55 335i
Sorry to bring an old thread back but where was this 20 amp fuse you found? Same thing happened to my car today and in the white electrical box, there aren't any brown fuses |
06-13-2022, 12:29 AM | #7 |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
Behind the glove box, google for the fuse box diagram
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
